Group Buys Members group buys
Waveguides and horns
Old 4th October 2012, 05:40 PM   #1201
Face is offline Face  United States
Face's Avatar
Will the horn be a mid in a three way or HF unit in a two way? If a three way, match the directivity at the top end to the HF driver your considering.
Sonograms at bottom of each link.
Horns
Horns
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 4th October 2012, 05:57 PM   #1202
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Jagaza, Thanks for the guidance.
Face,
Thanks for the links. A 2-way using the Denovo BA-750 over hybrid (rebuilt) JBL 2226 using 2235 parts and a longer voice coil. Heavy diy
Old 4th October 2012, 06:18 PM   #1203
jzagaja is offline jzagaja  Poland
Tweeter only. This is a midrange horn:
Horns
If we summarize all experiences and ideal would be Altec 416 coax in a midrange horn (200Hz) with full rollback (sphere) that forms bass reflex box tuned to 30-35Hz plus EOS waveguide inside speaker radiates from ground aka "Flooder"...
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 5th October 2012, 06:06 PM   #1204
Face's Avatar
Originally Posted by jzagaja View Post
Gentelman - please collect throat angles for favorite 1.4" and 2" drivers - I would like to start SEOS-20 or SEOS-24 prototype next week.
http://www.htguide.com/forum/showpos...&postcount=327
Sent from my DROID3 using Tapatalk 2
Old 8th October 2012, 07:26 PM   #1205
I must say DE500 with 12B100R is a nice combo - very, clean precise sound, tight bass, trully recommended.
Old 9th October 2012, 09:23 PM   #1206
Khanate is offline Khanate  Norway
Khanate's Avatar
Jzagaja; Would you recommend a horn for the DE500?
I've been looking at your Iwata 600 a couple of times as they provide relatively short height (vertical) at a relatively low recommended x-over frequency. And I want to build a compact two-way floor-standing system.
So for instance your recommended Beyma element @ 90L + DE500 and Iwata 600?
I would probably experiment with an active x-over setup, unless someone recommends a good passive diy-design that works.
Regards :-)
Old 10th October 2012, 05:38 AM   #1207
I recommend SEOS or OS with a below crossover:
Old 19th October 2012, 12:16 PM   #1208
Yummy Mummy :-)
Yummy Mummy | Hifi Pig
Old 19th October 2012, 09:39 PM   #1209
454Casull is offline 454Casull  Canada
HTGuide Forum
I want to say that Geddes measured an included angle of 13 degrees for the DE250. I wonder how accurate that list is.
Old 20th October 2012, 01:00 AM   #1210
gedlee is offline gedlee  United States
gedlee's Avatar
I didn't measure 13 degrees. I worked for B&C and 6 degrees was on the drawings.
Earl Geddes Gedlee Website
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
