Waveguides and horns - Page 114 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 30th May 2012, 12:06 PM   #1131
Hello,
I'm not expert in horns, drivers and a I've a question in my mind:
at the moment I'm using a Radian 475PB in my Sterling Silver Iris clone connected with a serie 7,5 ohm resistor to match the sensivity, now I'd like to buy a seos 12" plastic horn and try to use a lower crossover frequency (about 1,2Khz or a bit less)with a 12db cut.
I'm using a 8W SE amp for the woofer and tweeter, so the power is limited.
Do you think that the Radian Driver could be any problem of power handling and linear movement? And whych is in your opinion the lower 12db crossover frequency in this conditions.
Have a nice day.
Ciao
Guglielmo
Italy
Old 30th May 2012, 03:59 PM   #1132
Tytte71 is offline Tytte71  Norway
I have tried the 475PB on SEOS15. In my setup the 475PB created a sibiliant sound when crossed-over lower than 1400Hz - the lower the more sibilant the sound. I used a relatively steep FIR filter. However I enjoyed the 475PB when crossed over 1500Hz+. I don't want to jump into conclusions but switching to DE250 was a lot more successful story.
Please notice the increasing distortion on the 475PB below 1,3kHz (measurements taken on a fc500Hz Le Cléac'h profile horn - http://perso.orange.fr/francis.audio2/Comparaison_1pouce.pdf). It may be a source to the problems.
Old 31st May 2012, 07:57 AM   #1133
Hello,
I like very much my Radian's drivers (actually the cut is at 1,7Khz) but I'd like to try De250 with a lower cross over frequency, which is in your opinion the lower safe limit with a Seos12 horn and my 8w Amp using a 12db filter.
I red that the DE250 is a bit limited over 10Khz, may be necessary a super tweeter?Any suggestion?
Ciao
Guglielmo
Italy
Old 31st May 2012, 10:09 AM   #1134
SunRa is offline SunRa  Romania
Originally Posted by jzagaja View Post
Dr. Geddes style phase plug design stages. Optimized means all channels have OS curvature.
Hi, what are you using to simulate those designs?
And.. how do you interpret these sims?
Thanks!
Old 31st May 2012, 10:37 AM   #1135
Originally Posted by guglielmope View Post
Hello,
Ciao
Guglielmo
Italy
I also liked the Radian when using it 1500Hz+... I then prefered it over the DE250. DE250 is a safe choice but as you say, it is a little limited in the top octaves. Personally I haven't missed a super tweeter with the DE250 but it could very well be a good thing to try.
The XO frequency and filter order should be selected to give a flat power response in the transition between your tweeter and woofer.
Old 31st May 2012, 10:39 AM   #1136
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
I've used AxiDriver foir sims but I prefer compare stock plug with design plug by measuring directivity. I don't use sims anymore. This is for fun only.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 31st May 2012, 06:49 PM   #1137
As for the Radian 950/951-Be. For sure requires EQ in JMLC horn. Below is example of a filter built in Hypex DSP module (JMLC-200T horn).
Old 3rd June 2012, 01:40 AM   #1138
Attachment 284930
Attachment 284931
Does the 475PB have a faraday ring?
Hmm.. only me that would like to have SEOS with larger throat?
I think a 15" two-way is big enough as it is, so a 1" throat is perfectly fine with me.
I would however like a driver truly comparable to a TAD 2002, without the 4K/pr price tag, with the same ~13 deg exit angle to match the SEOS.
Do you know any European alternative to Dayton RSS390HF-4?
The closest I can think of, would be the ATC SB75-375S08 or the Volt r3853
Old 3rd June 2012, 11:50 AM   #1139
I don't know if the PB475 has Faraday ring, but that would normally have its advantage in the lowest frequencies, or?
I might have memorised a little wrong (long time since I tried the driver) - that the sibliance was pronounced already when trying 1400Hz XO. But I am confident that I had successfull results with XO at 1500. Yesterday I hooked the 475 to the SEOS 15 again and ran distorion tests indoor on the bare WG's. Measurement was done at 1m with a SPL of about 105db (have not SPL calibrated the rig). I observed that the driver has a mode at 1780Hz (48samples/octave). I then removed the backchamber and stuffed it into a damped tube and the overall distortion was severely reduced... will make a mod to the chamber and try the driver again with lower crossover after this. I did also run comparison with the DE250 and the distortion figures on this one may explain why I prefer the 475 when crossing over high
Regarding large throat on the SEOS (preferably SEOS18); By now I don't know of any alternative to the TAD2001/2002 and the 951 is a lot cheaper. I have never tried the TAD's but I do know that the upper mid and tweeter performance of the 951 outperforms any of the cheaper 1" I have tried. I can perfectly live with the beaming starting at 14/15kHz.
Edit: All tests done under exact same conditions
Old 3rd June 2012, 11:57 AM   #1140
FR compared to DE250
File Type: png FR Radian 475PB and B&C DE250 + SEOS15.png (44.7 KB, 728 views)
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 06:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 04:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 01:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 08:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 02:38 AM
Copyright ©1999-2017 diyAudio
