Group Buys Members group buys
Waveguides and horns
Old 13th May 2012, 10:43 AM   #1121
sendler is offline sendler  United States
Originally Posted by jzagaja View Post
Seven please
No drum kit in that song. Maybe track eight.
Scott
Old 13th May 2012, 10:54 AM   #1122
jzagaja is offline jzagaja  Poland
Haha see Silbatone
Btw: other presentations sound very good, strong resolving highs no boom.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 14th May 2012, 03:33 PM   #1123
marco_gea is offline marco_gea  Italy
Originally Posted by ra7 View Post
Jean,
My biggest concern in designing a passive crossover is accounting for the delay in HF arrival with respect to the woofer acoustic center.
TAD tackled this in their TSM series (aka 2401/2402) monitors by employing an asymmetric crossover, which I have recently reverse-engineered, based on the published schematics and frequency-response graphs.
Such crossover appears to work as follows:
Crossover frequency Fx = 650Hz
LF) 6th order electrical Low Pass > 6th order Linkwitz-Riley target @ Fx; normal polarity connection (+); phase @ Fx = -6*45=-270º
HF) 2nd order electrical High Pass > 3rd order Butterworth target @ Fx; inverted polarity connection (-); phase @ Fx = 3*45º-180º=-45º; level = -1dB
LF-HF offset set for phase match at Fx = (270-45)º = 225º = (5/8)*c/Fx = 5/8*34400/650 = 33cm
In attachment: (i) a technical drawing of the TSM-1 (2401) monitor, (ii) the filtered Woofer LP response, (iii) the filtered Compression Driver + Horn HP response, (iv) the passive crosssover schematic.
I actually plan to make a three-way crossover for my own high efficiency system soon, based on this design (by adding a super-tweeter and second crossover point at Fx2 = 10*Fx).
Marco
Old 14th May 2012, 04:37 PM   #1124
ra7 is offline ra7  United States
OMG! Thank you so much for this post. This is like goldust for me.
Will get back to you with some questions.
Old 16th May 2012, 12:02 PM   #1125
Jmmlc is offline Jmmlc  France
R.I.P.
Hello,
What you describe is only phase match but that does not means that this crossover + offset between loudspeakers is in anyway able to achieve linear phase linear phase which is needed for a constant group delay and optimal impulse response.
If we imagine to obtain the time delay required to compensate an offset around 33 centimeters through the crossover, we need a low-pass (Bessel for example) of a very degree (17 to 20 degree) with the cut-off frequency you indicated.
I guess that in the TAD monitor the goal was only to obtain a phase match and a smootgh variation of the lobing with frequency, not an optimal Impulse Response.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Marco
Old 16th May 2012, 04:51 PM   #1126
Originally Posted by Jmmlc View Post
Hello,
Dear Jean-Michel,
thank you for your contribution.
In a nutshell, yes, I agree completely.
The TAD crossover does not fully compensate for the physical offset between the woofer and compression driver. Moreover, by employing a L-R low pass instead of a Bessel one, the group delay (GD) of the woofer is not constant below Fx.
Ideally, one would like to achieve GD(LP)-GD(HP) = physical offset, with a constant GD for both crossover branches at and in the vicinity of Fx. That, and of course a quasi-flat summation and good phase match.
Still, the TAD crossover may be regarded as a reasonably good compromise, given that it does produce a flat summation and good phase match, despite the rather large 33cm offset dictated by the physical dimensions of the TH-4001 horn.
I am personally still investigating alternatives.
One such alternative which I have found to work quite nicely, at least in theory, is a 6th order Bessel LP + 2nd order Butterworth HP, both set so they are -6dB at Fx, with reversed polarity on the HP and an offset = 0.4*c/Fx.
For the same Fx = 650Hz as the TAD monitors, one gets offset = 22cm (good but not quite as much as with the TAD crossover, so the horn would have to sit forward with respect to how it is deployed in the TSM monitors).
One further potential problem, though, is that it is sometimes hard to achieve a true acoustical 2nd order HP with a typical horn...
On the positive side, this alternative crossover does meet the GD(LP)-GD(HP) = physical offset condition, and still sums flat.
I'll keep simulating other alternatives. For example, one could use an even steeper Bessel LP (e.g. 8th order - beyond that the insertion losses would be a major drawback, I guess), paired with some reasonable HP (2nd or 3rd order), to try and increase the offset while still achieving a flat summation, good phase match at Fx and ~constant GD difference.
Marco
Old 21st May 2012, 04:02 PM   #1127
Tytte71 is offline Tytte71  Norway
So far I have been very happy with the SEOS waveguides - in addition to IMO measuring, integrating and sounding very well, they are beatifully made. However, I feel the potential of the largest ones could have been even better released if allowed for larger drivers than the 1"-ers.
I would therefore suggest a little race to see how many that could be interested in the SEOS 15, 18 or 21 with 1,4" and/or 1,5" throats. If the interest is large enough I feel quite confident Jzagaja would make a mold or two
Personally I would love to have the SEOS 18 and 15 with 1,4" throat (Radian 951Be / 0º exit ). If possible I would also like to have the SEOS 18 for 1.5" JBL 2447 (unfortunately I don't know the exit angle).
Cheers
Old 24th May 2012, 06:57 AM   #1128
Hmm.. only me that would like to have SEOS with larger throat?
Old 27th May 2012, 10:26 PM   #1129
Dr. Geddes style phase plug design stages. Optimized means all channels have OS curvature.
Old 27th May 2012, 11:02 PM   #1130
dnewma04 is offline dnewma04  United States
I've got a few 1.4" and 2" throad compression drivers, but I'll count myself as one of those not interested in a larger diameter throat SEOS.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
