Group Buys Members group buys
Waveguides and horns
Old 30th April 2012, 03:27 PM   #1101
wdhro is offline wdhro  United States
Originally Posted by gedlee View Post
No, not in the least.
Physics requires that any source which is Constant Directivity cannot be flat on axis. Hence, the flat response is simply proof that the device is not constant directivity. I would be impressed if it fell at 6 dB/oct though - in the far-field that is, because everything looks good at 30 cm.
It can be flat on axis if the driver has a flat power response. Is that not the case below the mass corner? It's certainly something I've seen before. It's why we use shelf filters over the top portion of the bandwidth rather than across the entire operating region...
That said, I agree that the TAD drivers do not have a flat power response to 20kHz. Are plane-wave tube measurements a thing of the past?
Old 3rd May 2012, 05:04 PM   #1102
jzagaja is offline jzagaja  Poland
Hot pictures from München.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 4th May 2012, 04:56 PM   #1103
Romy's pictures:
GoodSoundClub - Romy the Cat's Audio Site - High End 2012 in Germany
Old 4th May 2012, 06:48 PM   #1104
phusis is offline phusis  Denmark
Thanks for the München pictures, Jacek!
Any reactions to the sound of the flatpack and/or Universum? Are the Universum's with the active bass module?
Old 4th May 2012, 06:52 PM   #1105
Still waiting for independent opinions - note that this two models were prepared only three weeks before trades, Universe virtually as we live 700km apart. What I know from initial trials is that DEQX or similar processor (OpenDRC+AcourateDRC) are highly recommended - DEQX is used by Autotech but only as a DAC (microphone failure). Universe uses active Kappa 15A. For more extensions we could try Dayton Reference. There were questions about open baffle construction as well.
Munich High End Show Report 2012 High End Society Show Coverage
Autotech rating:
no. 1 MBL
no. 2 Universe
no. 3 Cessaro
Old 6th May 2012, 09:40 PM   #1106
Has the München exhibition gone over well for Auto-tech?
You should've brought pair of properly run-in Mummy v2's as well - people would have eaten them up
Old 7th May 2012, 08:08 AM   #1107
vuki is offline vuki  Croatia
vuki's Avatar
The room was small, the sound was good. I listened to Universum - really good; balanced and natural sound.
Old 8th May 2012, 10:08 AM   #1108
leifchristensen is offline leifchristensen  Norway
Default 4001 in Autotech Iwata
Originally Posted by Gluca View Post
Hi Lukazs
where did you find those measurements?
(I am using 4001 and your/JMLC iwatas)
Gianluca
hello
where do you hipass the TD-4001 in that horn? slope? added tweeter?
doing extensive tests with JBL 2446 truextent and TAD TD-4001 in Norway
we have Iwata 300, CNC´d plywood Iwata 300, JMLC200T, TAD-TH4001, JBL 2360. In the bigger horns we´ve tried hipassing at down to 300-350Hz with mixed results.
target is to replace AG Trio above midbasshorns
best
Leif
Norway
Old 8th May 2012, 08:26 PM   #1109
SEOS 24 is ready with throat angle 14deg, waiting for TAD 4001, Radian 950/951 and 18sound ND4015BE, NSD1480N, ND2060A angles.
Old 8th May 2012, 09:06 PM   #1110
Carl_Huff is offline Carl_Huff  United States
Default IWATA 300 with Beyma CP750ti
I recently bolted on a pair of Beyma CP750ti CDs to my IWATA 300s. I really, really like the combination. They work very well together.
http://profesional.beyma.com/ingles/pdf/CP750Ti.pdf
Best Regards,
Carl Huff
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
