| Group Buys Members group buys |
#1071 |
Thanks!
I will make all source code open source, and executables will also be posted. The pcb is very simple (see circuit attached). The only "difficult" thing for DIYers will be programming the PIC and finding a suitable motor cheaply. I found a PITMANN motor on Ebay with a reduction of 63 and a 256 inc encoder for 30 €. Maxon motors with quadrature encoder show also up every now and then. For bearing I used one of these: Drehkranz Drehlager Drehteller Drehscheibe Ø 330 mm | eBay remark: I have no affiliation with this seller. I just posted this because it’s ideal to make an automated rotary table. This should allow many people there to build an automated rotary table. |
#1072 | |
Please post any questions there, then all information will be grouped. See DIY Automated rotary table for automatic polar measurements Last edited by _Wim_; 11th April 2012 at 06:53 PM. Reason: Added link to thread |
#1073 |
Beyma 12BR100 close-ups.
Visit us at http://www.horns.pl/ The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here |
#1074 |
Measured t/s:
Fs = 31 Hz Re = 6.2 ohms[dc] Le = 0.87 mH Qt = 0.36 Qes = 0.37 Qms = 11.11 Mms = 80.5 grams Rms = 1.4 kg/s Cms = 334 um/N Vas = 132 liters Sd= 530 cm^2 Bl = 16.2 Tm ETA = 0.99 % Lp(2.83V/1m) = 93.2 dB Added Mass Method: Added mass = 32.00 grams Diameter= 26.00 cm
Visit us at http://www.horns.pl/ The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here Last edited by jzagaja; 14th April 2012 at 08:21 PM. |
#1075 |
This translates to 5Hz lower -3dB point against 12BR70. I will be making another Mummy (Ferrari Red) with 12BR100 and DE500 and compare with BMS 4524+12BR70.
#1076 |
I am looking forward to this, these are the drives I want to try myself in these enclosure.
#1077 |
Distortion figures without taking care of mounting i.e. speaker lies on a carpet. Voltage is 2,87Vpp measured at 50Hz.
#1078 | |
. Also impedance and time domain measurements is interesting to see!
#1079 |
Will try. In the meantime impedance.
#1080 |
Compared to 12BR70.
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 14 | 30th January 2013 05:20 PM |
| Horns inside of horns open foe discussion | oilcanracer | Multi-Way | 3 | 15th February 2010 03:42 AM |
| Compression drivers in horns or waveguides | 454Casull | Multi-Way | 6 | 1st December 2008 12:41 PM |
| Phase plug necessity in horns/waveguides | 454Casull | Multi-Way | 3 | 18th September 2005 07:36 PM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
