Group Buys Members group buys
Waveguides and horns
Old 26th March 2012, 04:54 PM   #1051
phusis is offline phusis  Denmark
Originally Posted by jzagaja View Post
D500 rings slightly near 20kHz while D800 between 10-20kHz. Trying to get NSD1095N. New 18sound beryllium driver is now listed on website.
That's some nasty break-ups from the D800. The DE500 curve looks very respectable, actually, and the near 20kHz break-up here mayn't be cause for much concern.
The 18sound beryllium driver sports a 4" VC, doesn't it? Well, if JBL can squeeze their 4" beryllium driver in the Everests to reach some 15+kHz, supposedly in an acceptable manner, why shouldn't 18sound be able to do so with their driver? Perhaps I'm holding on naively to the hope of seeing a 4" compression driver going unassisted towards the 15-20kHz region...
Old 27th March 2012, 04:19 PM   #1052
Tytte71 is offline Tytte71  Norway
If not ruler flat to 20k it is at least an interesting large format driver option Radian Audio 951PB/Truextent Be4016
Old 27th March 2012, 04:40 PM   #1053
jzagaja is offline jzagaja  Poland
K+T Data 5.2011.
File Type: jpg Radian 951PB_Truextent Be4016_BLS Horn_K+T 5.2011 Klein.jpg (843.7 KB, 852 views)
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 29th March 2012, 08:55 PM   #1054
E-JMLC-1400 and JMLC-1400 with B&C DE7.
Old 31st March 2012, 09:31 AM   #1055
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
E-JMLC-1400.
now this one looks good, what are the dimensions? (picture?) is it intended for use with 6" ?
Old 31st March 2012, 09:46 AM   #1056
220x86x93mm (WxHxD).
Old 31st March 2012, 08:41 PM   #1057
BK turntable from 60s for polar measurements, very well built. Going to install small stepping motor inside. Bought Slo-Syn SS25-1001 (11.8V, 0.44A, 5 wire unipolar) and Atmega 8 USB controller (AVT 2933), first run:
IMG_0049.MOV - YouTube
80-20m Magnetic Loop Antenna by Frank N4SPP
Old 1st April 2012, 06:46 AM   #1058
_Wim_ is offline _Wim_  Belgium
Hello,
I am also working on an automated rotary table (nearly finished). It uses a pic microcontroller that communicates over USB. The USB framework came from this excellent site:
Open Source Framework for USB Generic HID devices based on the PIC18F and Windows - WFFwiki
Status so far:
- C# test application in finished. It can servo control a motor with encoder (I used a pittman motor from Ebay)
- Rotary table is mechanically finished
- Now working on Auto-it script to control the rotary table and Arta automatically
Goal: take polar response data with 1 mouseclick
When finished I will post code here on DIYAudio.
Old 5th April 2012, 01:10 PM   #1059
JoeS is offline JoeS  Germany
Default Horn Tractrix, JMLC or E-JMLC for BMS 4590 / 4592
Hello,
I saw that Autotech will exhibit on the always excellent "High End" 2012 fair in Munich in first week of May. Good chance to see tangible products in real world again!
@jzagaia, will you be present too?
I like to select a good combination of Autotech Horns for use with BMS 4592. LF will come from room corner horns with 18". X-over approx 400Hz.
I had in mind Tractrix 200, E-JMLC 300, IWATA 300, JMLC 350 (JMLC 200t is too big).
Roomsize 4,5 x 7 m
Who can give some directions here?
Many thanks
Old 5th April 2012, 05:34 PM   #1060
This year Autotech @ Munich can play music I won't be there, it's time for a brake from audio With a wide bandwidth 2" drivers JMLC-350 or EJMLC-300 are suitable.
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
