Group Buys Members group buys
Waveguides and horns
Old 14th March 2012, 09:32 PM   #1031
jzagaja is offline jzagaja  Poland
SEOS-10 Flatpack:
made out of solid surface, as a kit for self assembly initiated by Erich (diysoundgroup). Cost unknown yet as it's prototype but for masses so keept low. Larger will come later.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 14th March 2012, 09:36 PM   #1032
phusis is offline phusis  Denmark
Originally Posted by jzagaja View Post
SEOS-10 Flatpack:
Ok, thanks.
What drivers(size, etc.) are thought to be used in the larger version - twin 15" per side as in the Everest?! Unless of course you're referring to the JBL K2's, which comprises one 15"
But, a great concept/initiative! I'm definately very curious about info on the larger version as well...
Old 14th March 2012, 09:52 PM   #1033
Depends how big the back you want a pair of Sonido SCW300 (10cuft), Beyma 12BR100 (5cuft) or any low power BC, 18 sound, Eminence etc.
Old 14th March 2012, 09:56 PM   #1034
Well, bring it on - 15 inches would be appreciated as well(EDIT: oh, you speak of pairs!!) The Beyma 12B100/R looks to be very appealing, speaking of 12" inch units, and then imagine two of them - my god, what a bliss...
Old 14th March 2012, 10:27 PM   #1035
PeterDupont is offline PeterDupont  Denmark
Please,
Any responce from a 4" compression driver above 10 kHx consists of heavily distortion rather than the sinusoidial input.- or music.
I have four Radian 950 here, two with Truexteent - and they all show the same dirty top-end above 10 khz.
Old 22nd March 2012, 07:34 PM   #1036
White SS-SEOS
aka "poured" or "cement"
Old 22nd March 2012, 11:17 PM   #1037
A little play with Acourate. SEOS-15+4538 equalized to 20deg (EQ filter not shown) versus ejmlc-600 + DE250 (EQ filter shown) equalized to 0 deg in a range 600-16800Hz.
Old 23rd March 2012, 08:58 AM   #1038
Jmmlc is offline Jmmlc  France
R.I.P.
Hello Jack,
http://www.diyaudio.com/forums/attac...mlc-600-eq.gif
to be compared with the optimum frequency responses curves for stereophony defined by Earl Geddes in his paper on directivity :
http://www.gedlee.com/downloads/directivity.pdf
see figure N° 11
Here attached figure 11 (from that paper, copyright Earl Geddes)
Best regards from Paris, France
Jean-Michel Le Cléac'h
Old 23rd March 2012, 02:28 PM   #1039
gedlee is offline gedlee  United States
gedlee's Avatar
Jean-Michel
I think that you are taking my data a out of context. The lower figure in yours (the room/speaker layout) has nothing to do with the main figure, the two are describing different things, but you are linking them together. The curve that you show is not "optimal" in the sense of "desired" (I will admit to using the wrong words in my paper - I will correct that) but they are examples of what should be expected given some physical limitations of acoustics being described - namely that the lower frequyencies cannot have directivity but the higher frequencies always will. Hence, the purpose of figure 11 was not to show the "ideal" but to show what is likely to happen.
Thanks for pointing this out as rereading the paper this section could easily be misinterpreted as you have just shown. I will correct it shortly. To represent what you are trying to say they do represent, the curves should be much closer together and flat not curving downward.
Earl Geddes Gedlee Website
Old 23rd March 2012, 03:41 PM   #1040
R.I.P.
Hello Earl,
I remember that several authors (Keele being on of them I think) admitted that in the case of conventional loudspeakers (not CD designs) such limited increase in directivity and such orientation of the loudspeaker axis is benefitial to a wider spread of the listening area and to a better sterophony.
Best regards,
Waveguides and hornsHide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 06:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 04:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 01:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 08:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 02:38 AM
