Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 9th March 2012, 10:06 PM   #1011
Originally Posted by TerribleT View Post
Nice set up you have there. Can you give some specifics on the drivers in the VOT boxes and the crossover? Are you using the original Iwatas that does not have metal reinforment in the driver flange area? I am wondering about long term stability of the horn hanging off the drivers like you have. Do you think they will hold up over time and not develope fractures in the stressed areas?
Thanks,
David
PS I'm still wondering about Altec drivers used in Iwatas. Anybody have any experiences with this combo?
Hello David,
Those are the original IWATAs that did not have the metal reinforcement ring. They were weak. In fact one of mine broke. The waveguide pulled completely free of the MDF mounting ring. When I made the repair I added fiberglass to build up the transition from MDF flange to waveguide. The fix worked and I don't think there is much of a chance that they will come apart again.
The driver in the VOTT box is a GPA 416C. GPA makes a very nice product. Their 416C driver in a stock Altec 828 cabinet is usable (with boost) to 40Hz. The crossover is active and is set at 650Hz / 18dB per octave. I use Dirac Live running in a Datasat RS20i Processor to smooth the response. Bass Management extends the bottom end to 20Hz. I'm very happy with the results.
Best Regards,
Carl Huff
Old 10th March 2012, 02:18 PM   #1012
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Any preliminary specs for woofer cutout diameter and enclosure volume for the SEOS-10 flat pack? Thanks.
257mm dia, 1cuft. DE250+10CL51. RAW responses enclosed.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 10th March 2012, 04:15 PM   #1013
JMLC-200T solid surface edition, perfect craftsmanship, rollback joint is smooth, gloss deep.
Old 10th March 2012, 07:50 PM   #1014
Radian 950PB Truextent in JMLC-200T.
Old 10th March 2012, 07:59 PM   #1015
Compared to 4590.
Old 10th March 2012, 10:38 PM   #1016
phusis is offline phusis  Denmark
jzagaja -
(being a non-techie myself..)
How would interprete the differences between the BMS 4590 and Radian 950PB True extent in the measured comparison? The impulse response of the Radian unit seems "cleaner" to me..
Old 11th March 2012, 07:16 AM   #1017
Brett's Avatar
Originally Posted by jzagaja View Post
Compared to 4590.
What xover was used for this measurement? Or is it only the MR section of the 4590?
Old 11th March 2012, 07:30 AM   #1018
4590 - 1uF on HF unit out of phase, no crossover on rest. Hard to tell subjevtive difference as i have only one Radian, BMS has more sparkle. Radian look is awesome and it's light.
Old 11th March 2012, 07:36 AM   #1019
Brett's Avatar
Cheers for that info. Not the way I'd use the 4590 myself: I much preferred a a steep active xover at 6k5. Notwithstanding my preferences, most people would have something more there than what you have, so not too much should be made of the comparison between it and the radian, based on that.
Old 11th March 2012, 08:30 AM   #1020
Radian has a step at the output of phase plug.
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Compression drivers in horns or waveguides 454Casull Multi-Way 6 1st December 2008 12:41 PM
Phase plug necessity in horns/waveguides 454Casull Multi-Way 3 18th September 2005 07:36 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Copyright ©1999-2013 diyAudio
