LSK389C SOIC-8 Group Buy - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 2nd June 2010, 08:11 PM   #121
EUVL is offline EUVL  Europe
EUVL 30
merlin-el-mago 30
fredlock 10
pchw 10
mikel_ann 10
ginum 10
grufti 20
Sum: 120
Old 3rd June 2010, 11:10 AM   #122
Digi-Key - S9016E-07-ND (Manufacturer - GRPB071VWCN-RC)
Pull out pin 2, 4, 6. Then you are left with 4 pins for drains & source.
A 3-pin version with pin 2 removed will take care of the 2 gates on the reverse side of the PCB.
Low cost, easy to get ....
Patrick
Old 3rd June 2010, 11:29 AM   #123
Patrick
perfect idea, you found, but after removing 2, 4, 6 it should be possible
to use 2 of them on the other side.
Michael
Old 3rd June 2010, 11:42 AM   #124
If you can get 0.5mm (or even better at 0.4mm) thick PCB, then they will be perfect as the plastic part is 2.14mm thick.
So the 2 rows of pins (D & S on front side, gates at the back) will end up almost exactly 2.54mm apart, as in 2SK389.
Patrick
Old 3rd June 2010, 04:19 PM   #125
0,5 mm is possible at same price.
150 - 200 pcs is target quantity, so guys come on
Michael
Old 11th June 2010, 09:07 PM   #126
Default Adaptor Board
After a busy week I ordered the boards today and expect to
receive them in 2-3 weeks.
Price is 4 EUR / 10 boards + 1,50 EUR pp as standard letter.
If you like this pin header:
may be shipping might be a little higher.
Please send an e-mail to mgriessbach@ctech-suew.de
with
1. quantity boards you want
2. quantity pinheader
3. shipping address
regards Michael
Old 11th June 2010, 10:32 PM   #127
Michael,
If you want to be totally compatible to the 2SK389, you will need
1x S9016E-07-ND AND 1x S9016E-03-ND (I am afraid)
so that you can have the 2 gate pins offset to the drain & source by 2.5mm.
Patrick
Old 22nd June 2010, 05:11 PM   #128
merlin el mago's Avatar
It's finally ready? Do you create a GB where people can ask they wants? prices, expected time to receive the adaptors,etc. As I understood the adaptor will be to replace the trough hole 2SK389BL, right?
Thanks a lot in advance
Best
Old 22nd June 2010, 05:39 PM   #129
luvdunhill's Avatar
I still have a bunch of adapters that I made back in the day, if anyone wants some.
The pins are installed first, then the device is soldered on top. The trick is to place the pins inside a zigzag socket (or using the PCB that you're about to install the device in as a guide works) while soldering the pins and the device.
I like Patrick's solution though, but I've done probably 25 or so in the above manner, so it can be done.
Old 22nd June 2010, 06:05 PM   #130
My solution is better. Less footprint, easier to solder.
Michael is busy. I also have not heard from him.
But we agreed to order enough for everyone.
And price will be much less than 1 Euroa piece, but depends how many can be accounted for.
Be patience,
Patrick
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 02:03 PM
Ad8599 group buy ? ashok Parts 0 25th June 2007 05:33 AM
TDA1541A group buy?? genome Group Buys 1 18th September 2004 10:30 PM
Copyright 1999-2017 diyAudio
