Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 2nd December 2010, 01:16 PM   #931
regiregi22's Avatar
you can lay out the trafos and the boards attached to the heatsinks and measure. Then turn them 90º or 180º and measure again. That should be an easy fast operation if you don't screw the boards with bolts
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 2nd December 2010, 03:32 PM   #932
I'm not sure what kind of noise you're concerned about shielding against. If it's noise from the traffo and AC, there is no need to take any extraordinary precautions. My amps are mounted only a couple inches away from the traffo, and they are stone silent. All that lies between the amps and their traffo is the power supply caps. You do not need to arrange heatsinks to block anything. In fact, having to route AC around heatsink, past the amplifier to the traffo may cause more noise from cabling than it helps avoid. Use the simplest, most direct routing of ALL internal wiring, especially signal input, and you need take no further precautions.
Old 2nd December 2010, 04:04 PM   #933
Just curious... Although the idea of reading through 93 pages of posts sounds AWESOME, I just wanted to know if this group buy already went through. Was kinda hoping I could get in on the fun! The date range for these posts are pretty far apart, so I assume it has gone through.
Old 2nd December 2010, 04:31 PM   #934
This GB is finished.
Another may start up, but be prepared to wait.
This or it's sister thread may come sooner:
MyRef RevD - successor to RevC
regards Andrew T.
Old 2nd December 2010, 05:32 PM   #935
udailey is offline udailey  United States
Passive Aggressive
AND linuxguru has boards right now for his iteration of the MyREFC which is quite similar to this one AND it has room on the board for all components whereas this board in this thread was quite cramped for room with all the component swapping we did.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 3rd December 2010, 01:25 AM   #936
ben-jam-in's Avatar
I just wanted to say what a gem this amp turned out to be. The ref C biamping mono's have been going strong for a couple months now. I built them for my brother, both he and I are very happy with them.
I Want to say thanks to all the people who put a lot of hard work into the group buy, as well as to the people who spent a lot of time swapping parts, tuning the sound. The Ref C is just an awesome amplifier, It puts my "regular" chip amp to shame.
Thanks everyone,
Ben
Old 3rd December 2010, 02:25 AM   #937
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default Re... Shielding
Originally Posted by billo44 View Post
I am just about ready to start laying out the 'bits' in the case for my amp.
I am curious... I saw Lazarus quote above and thought that's a good idea! I'll do that.
Now I am wondering if a big aluminium heat sink actually has more shielding effect than the power supply caps would? In that case I would be better with toroids one side of the heat sink and amp boards the other?
I have a strip of suitable heat sink long enough to take two amp boards comfortably.
Does anyone have any thoughts on this?
I'm just thinking aloud....
Cheers
Bill
Dear Andrew, Regi and Madisonears, thanks for your posts.
Helpful ideas, and comments! I wish I had the wherewithal two build two amps Andrew... but I can as Regi suggests try a few different layouts and watch for AC noise on a scope at the output.
Madison ears the simple practical advice is very welcome and sounds good. Nice looking amp you built there! Can you ID the cap you appear to be using across the mains switch?
They should be safety rated shouldn't they? I was looking for a suitable cap for 100V AC mains switches and getting confused by too much information on the intrawebular thingy.
I'm easily confused I fear!
Thanks again
Bill
Old 18th July 2011, 03:24 PM   #938
cersepn is offline cersepn  United States
i'm late to the party, but does anyone have spare boards/kits they wish to sell?
B1 Buffer Preamp BOM davidfmartin Pass Labs 1 12th December 2011 10:27 PM
New builder: Proposed BOM joekraska Parts 0 31st December 2009 02:41 PM
New builder: Proposed BOM joekraska Class D 1 31st December 2009 05:06 AM
BOM needed for Mark Kelly controller exurbia Analogue Source 4 4th October 2009 02:01 PM
wanted :100W Aleph X (kari's board) bom/parts list dhole Pass Labs 32 19th March 2006 11:27 AM
Page generated in 0.11491 seconds (73.57% PHP - 26.43% MySQL) with 11 queries
