| Group Buys Members group buys |
#101 |
I'm interested in a kit (stereo pair)
#102 |
Passive Aggressive
Guys,
Whats the difference between MKP4 or 2 and FKP2? Are we basically talking lead spacing here? There are a few values not available at one distributor in FKP but are in MKP or the other way around and some are available in MKP2 but not MKP4. Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#103 |
Passive Aggressive
Another if anyone remembers
THE BC546 comes in a few different HFE values from 100mA to 400mA. Does anyone recall if that was specified? Part number for the relay. I dont have it anymore. I remember this thing was a pain to get enough of. Uriah
#104 |
Uriah,
The kit I received had the BC546B. The relay was this one: G5LE-14-DC24 Omron Electronics General Purpose / Industrial Relays |
#105 |
Passive Aggressive
Grimmy!
Thanks for that information. Awesome. I dont think I am going to include the 38 dollar input capacitor unless a bunch of you request it. Its an important piece of the puzzle but you probably already have a DC free signal to your amps from your pre or your CDP. Plus at QTY 100 kits thats 38 dollars times 200. Crazy. Uriah
#106 |
Uriah,
MKP is WIMA's designation for metallized polypropylene film cap. 4 and 2 designate the package geometry. All MKP2's are 5mm spacing in a square package. MKP4 can be from 7.5mm to 37.5mm lead spacing in an oblong package. FKP2 is a stacked film and foil cap in a square package with 5mm lead spacing, and is a better sounding cap. I believe this would be most important at C21. Peace, Tom E |
#107 |
The $34 Fostex input cap from Madisound(copper and tin foil) is not essential, but it is a very good idea to have a cap there. Any DC at the input, even unexpectedly, would prove disastrous for speakers, possibly the entire amp. So, the old argument: spend for a nice input cap or buy new drivers?
There are other film and foil caps available for less money. Dario is happy with the Mundorf ZN (tin foil) at half the price from Parts Connexion. I tried a cheaper film and foil cap of similar construction, Auricap Theta (tin foil) from Parts Express, and wasn't satisfied because it sounded bright to me. Others might appreciate the overwhelming amount of detail and sense of depth. I think a 1.0uf cap is big enough at this position. I use a 0.68uf, and I still have plenty of solid, deep bass. The important thing is to use a film and foil cap, NOT a metallized film. It will cost more and be bigger, but it will impart a three dimensionality to the sound that cannot be had with a meatllized film cap, even a very expensive one. I expect that such a high price item would be considerably cheaper in a large quantity and might even be subject to direct negotiation with the supplier. The problem might be availability of such a large quantity. Perhaps you should add a column to the spread sheet for builders to elect buying an appropriate cap in the kit or buy their own or risk leaving it out entirely. We could still get a nice discount for more than ten. Peace, Tom E Last edited by madisonears; 4th March 2010 at 10:23 PM. |
#108 | |
The MKP4 it's actually available from Mouser (pay attention, with the same code two articles...click the link for the right one) Where I've specified FKP2 it should be FKP2 because it makes an audible difference. FKP2 1000pF is available from Mouser (505-FKP21000/100/5 >1000) FKP2 22nF is available from Mouser (505-FKP20.022/63/2.5 >300) FKP2 150pF is available from Mouser (505-FKP2150/100/2.5 >600) I've found an error with the MKP2 100nF reccomendation, I've ordered it and it's too big (could be fitted but not perfectly) so it's problably better to go for a MKS2 100nF (505-MKS2.1/63/10) or 220nF (505-MKS20.22/63/10), both would fit. The 0.1 uF opamp bypass could be either a MKS2 or a MKP2.
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#109 | |
Relay OMRON G5LE-14-DC24 (Mouser 653-G5LE-14-DC24 , Digikey Z1013-ND) From Mouser is available (>3500), no stock at Digikey
#110 | |
Obbligatos are a good choice too and costs only 8$ each. Uriah, you have mail...
| B1 Buffer Preamp BOM | davidfmartin | Pass Labs | 1 | 12th December 2011 10:27 PM |
| New builder: Proposed BOM | joekraska | Parts | 0 | 31st December 2009 02:41 PM |
| New builder: Proposed BOM | joekraska | Class D | 1 | 31st December 2009 05:06 AM |
| BOM needed for Mark Kelly controller | exurbia | Analogue Source | 4 | 4th October 2009 02:01 PM |
| wanted :100W Aleph X (kari's board) bom/parts list | dhole | Pass Labs | 32 | 19th March 2006 11:27 AM |
| Page generated in 0.12171 seconds (79.89% PHP - 20.11% MySQL) with 11 queries |
