Group Buys Members group buys
Ultra high precision Volume module like Mark Levinsion's
Old 12th December 2009, 08:32 AM   #1
bbp is offline bbp  China
Default Ultra high precision Volume module like Mark Levinsion's
Finally, I collect enough information to design such a REAL R-2R attenuator.
Fully balanced attenuation through 16 bit R-2R resistor network.
65535 steps current attenuations available, two Ultra low-noise low distortion OPAMP AD797AR were used as I/V convertor, the same structure as the module in Mark Levinson's No.32 ^_^
Considerate LAYOUT, 4-LAYERS PCB with 2 Oz copper,thanks Mark ^_^
Considerate POWER MANAGEMENT, onboard ultra-high performance linear regulator
High-precison SMT chip resistors
Simple data interface for micro controller
dimension:5545mil*2135mil
current switches: DG413DY, ultra precision analog switches
I/V convertor : AD797AR, ultra low-noise,ultra low distortion OP from ADI
Onboard regulator:LT1355
Resistors : YAGEO RT series @ 1% tolerance
The PCB will arrive next week, I will assemble the whole module and test then.
Anyone interest in it? ^_^
calm down and enjoy your time in experiment
Old 12th December 2009, 08:44 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
If you have 65535 steps and an R-2R ladder, you need far better than 1% tolerance resistors. You need 0.001%. I've no idea where you'd get such things.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 12th December 2009, 08:55 AM   #3
we don't need such high precision resistors up to 0.001%, 1% is enough in this application. even though, Mark Levinsion's product uses 5% resistors in their module in No.32, 1% resistors in No.320s/326s ^_^
We don't need a tolerance = 1/65535=0.00001526 in each step, just think about the R-2R DACs like PCM1704U-K ^_^
Old 12th December 2009, 05:13 PM   #4
EC8010's Avatar
You might not need 0.001%, but you do need better than 1% if you want to keep the errors down and make the accuracy reflect the precision. I'm assuming you don't actually make all those 65535 steps available to the user, but actually code for a logarithmic law and pick codes that give 1dB steps. At 6dB of attenuation, 1% resistors give an uncertainty in attenuation of 1.4%, and between channels of 2%, or 0.2dB. Stepped balance controls typically go in steps of 0.25dB, so those 1% resistors could cause balance error of one balance step. I don't see that a stepped attenuator is entitled to any balance errors, so whilst 0.001% isn't necessary after all, I think you need better than 1%, and 5% is certainly not good enough.
Old 12th December 2009, 06:45 PM   #5
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
i find it rather strange that mark levinson would use 5% tolerance resistors in the precision attenuator in such a flagship product as the no.32 preamp.
are you sure about your source of information?
mlloyd1
Old 12th December 2009, 08:03 PM   #6
cbdb is offline cbdb  Canada
How did you figure that? I get more like .01db.
10 log 100= 20, for 2% error: 10 log 102=20.09 or .09db error, for 5% 10 log 105=20.21 or .21db.
So the 1% tolerances are fine and even the 5% would be fairly inaudible.
Old 13th December 2009, 01:32 AM   #7
mlloyd1
Hi mollyd1,
I just download the image from Mark's website and found this >_< But I'm not sure all the version of different date manufactured module uses the same 5% resistors
regards
bbp
Old 13th December 2009, 01:49 AM   #8
Of course we don't need all the 65535 steps in the actual application,I plan to make the attenuations adding 0.1 dB/step from -96dB to -46dB and 1 dB/step from -46 to 0 dB.
That means I need to calculate the relationship for decimal/dB >_<
For the tolerance, 0.1dB is equal to 1.14%
Old 13th December 2009, 10:56 AM   #9
EC8010's Avatar
No, I'm afraid your calculations above are incorrect. A 1% error would mean that the attenuation was 0.99 or 1.01 of what it ought to be. Further, 10 log is for powers, but potential dividers deal with voltages, so we use 20 log. Taking the 0.99 case, 20 * log(0.99) = -0.087dB - near enough 0.1dB.
Old 13th December 2009, 01:27 PM   #10
Acutally divides current ^_^
Ultra high precision Volume module like Mark Levinsion'sHide this!Advertise here!
Ultra high precision digital control attenuator bbp Solid State 25 3rd May 2013 08:31 PM
Ultra Small NXV200 Module The Saint Vendor's Bazaar 8 30th September 2008 04:31 PM
Silicon Chip Ultra LD Mk2 Module pheonix358 Solid State 0 30th July 2008 06:25 AM
Alpha Ultra precision metal foil resistors pjpoes Parts 5 7th September 2005 01:47 AM
Copyright ©1999-2017 diyAudio
