Group Buys Members group buys
Tube-I-zator Professional PCB
Old 11th June 2013, 09:15 PM   #831
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Great, how are you going to stick all that into a case?
Does your reference PSU have multiple voltage outputs thru that connector?
Old 12th June 2013, 04:34 AM   #832
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
I will find a way to get all parts in a case
All needed voltages goes through the military connector HERE.
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB
Stock status in my Blog
Old 12th June 2013, 04:56 AM   #833
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
Oliver,
Do you have that latest board that has fix for the bugs (47k resistor, heatsink mounting holes) you mentioned way back then?
Also, can we use 6h30 tubes here?
Old 12th June 2013, 06:07 AM   #834
Originally Posted by Lil Knight View Post
Oliver,
Hi Lil,
the next batch will correct the two small bugs, but it´s really no big thing.
In principal you could use also the 6H30, but i haven´t any recommended B+, Rk & R I/V values for this tube.
Old 23rd July 2013, 11:36 AM   #835
Originally Posted by dvb projekt View Post
Bargain Sale
Here you could order my ready build Tube-I-zator test module
(excl. Tubes, Rk & R I/V)
Main Parts
- Nichicon KX Series caps (HV-PSU)
- Panasonic FM Series caps (Heater PSU)
- Mundorf MCap EVO aluminium/oil 2.2µF output caps
- Fairchild ISL9R460PF2 Stealth rectifier diodes
for the special price of
$99
including
Worldwide shipping and paypal fee
If you are interested, please send me a PM.
Sold!
Old 24th August 2013, 11:28 AM   #836
liquidsord is offline liquidsord  United States
Q. I want to incorporate SSHV. My voltages are 290v rectified to C-R-C. R=6.6k. When I add heater supply to tubes I get 284v before 6.6k and 222v after on anode. C=120u 400v for both. when the heaters turn off the voltage goes 290v. Iam thinking I can add higher resistor for C maybe 12k or so to bring V down to 170ish. I see an initial spike of 264v on power up as the tubes warm up gradually dropping down to 222v after 4-5 seconds. How dose this sound. My concern is the initial V spike at power up. THX
Old 21st October 2013, 09:51 AM   #837
jcastellano is offline jcastellano  Spain
Question Bias current injection...
Hi Oliver,
Is it mandatory to install the resistors in the tubes to inject the bias current injection to the TDA1541A? I have not done it and it sounds ok for me, a little lower volume level than other DACs but fine. Any clues?
Jorge
Old 21st October 2013, 10:17 AM   #838
Originally Posted by jcastellano View Post
Hi Oliver,
Jorge
Hi Jorge,
if you use the SSHV for B+ i strongly recommend to inject the 2mA bias current (SSHV out 150V --> 75K0 --> R I/V), because we get a high quality CCS here!
It takes 5 min. and you will get the max. performance out of the TDA1541A.
Oliver
Old 21st October 2013, 10:21 AM   #839
Talking Thanks Oliver...
Hi Jorge,
Oliver
I will do it ASAP!!
Thanks!!
Jorge
Old 30th October 2013, 10:34 PM   #840
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Originally Posted by DQ828 View Post
DVD
Crom just made me aware of the Rohpoint GG102A resistors that you are recommending
Do you have any idea what value would be suitable for BIII as the I/V resistors?
Also in the attached photo's it shows little brass stand offs, do you know what they are called I'm having trouble finding them?
Where can I buy thoose resistors ?
Tube-I-zator Professional PCBHide this!Advertise here!
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 02:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 04:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 05:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 09:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 11:06 AM
