Group Buys Members group buys
Tube-I-zator Professional PCB
Old 6th March 2013, 08:30 PM   #741
DQ828 is offline DQ828  Australia
DQ828's Avatar
DVD
Crom just made me aware of the Rohpoint GG102A resistors that you are recommending
Do you have any idea what value would be suitable for BIII as the I/V resistors?
Also in the attached photo's it shows little brass stand offs, do you know what they are called I'm having trouble finding them?
Old 6th March 2013, 10:42 PM   #742
Crom is offline Crom  United Kingdom
DQ828, Phew, glad you saw that tb1- tb2 connection that was needed -that's what I was trying to point out to you a while back. Make sure it happens on the tube side as per picture.
Re the I/V resistor, I'm using stock 56R and it sounds lovely. Russ / Brian from Twisted pear seem to recommend experimenting from 20R-32R so I've bought a few options which I'll be trying over the next week or so. I'll report back. I think the difference that you should notice is that it distorts (or you lose separation between the instruments) when you play it loud. I think it has something to do with the ability to deal with voltage swings. However, if someone can explain the logic behind the values I'm all ears ;-)
Old 7th March 2013, 12:06 AM   #743
DQ828's Avatar
Yes, thank you, I was torn between advice.
Old 7th March 2013, 12:54 AM   #744
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
I was using 30R and it sounded better than 56R in my tests.
BTW, if anyone wants a Tube-I-Zator, I'm selling mine. I changed my entire DAC so it is available.
Don't get me wrong, it is an absolute amazing I/V but I decided to leave tubes for a while. In all I have built 4 of the Tube-I-Zator!
I had a balanced setup but one is already sold. I'm using ClarityCAP MR on coupling and TX-2575 for R I/V (x2) and Rk (x4). Salas SSHV2 for high tension and the Tubes are TJ Full Music 12AX7. All parts are very good quality.
See here : http://www.diyaudio.com/forums/swap-...or-dac-iv.html
See here for my first two boards using DVBProjekt / Salas SSHV1 post #543
http://www.diyaudio.com/forums/group...al-pcb-55.html
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 7th March 2013, 01:42 AM   #745
palmito is offline palmito  United States
palmito's Avatar
Default OT question...
In the photo of post #741, where can I get the little sockets the resistors are plugged into? They look ideal (as their use in the photo suggests) to swap things and test them without soldering/desoldering. Thanks.
Old 7th March 2013, 06:59 AM   #746
DQ828's Avatar
That's what I want to know
Old 7th March 2013, 08:57 AM   #747
DQ828's Avatar
Well with the yellow wire in place it makes no difference to the voltage, The SSHV Vin is reading 161V & the Vout is reading 151V DC this is after about 20min with the tubes in place.
I still have one very hot heat sink & one luck warn, if fact it may be picking it's heat up from the heat sink beside it, as you don't need to put you finger on it to know it's hot ouch.
Old 7th March 2013, 01:02 PM   #748
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
The different temperatures on the heatsinks are normal. In our configuration we have a power dissipation of ~5.8W for IRF840 and ~1.2W for IRF9610.
With the usage of R1=56R (current adj.) we get a constant current of ~40mA.
If everything is ok, the SSHV input voltage should be ~180VDC.
I remember that one member had a problem with his transformer, witch wasnt able to get a stable voltage for 40mA current...
Anyway, how changes your input voltage, when you turn the output voltage slowly down?
Perhaps we must lower the resistor value in the C-R-C filter a bit, to get more input voltage to the SSHV.
And lastly is it normal for the heater elements to glow brightly for about a second when you first turn it on?
The heater flash on startup is normal for a wide family of tubes. Nothing to worry about.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 7th March 2013, 04:13 PM   #749
Get normal 2.54mm component straight sockets like the Mill-Max 310...001 series. Get rid of the plastic and you could use the pins as on my photo
Old 7th March 2013, 04:25 PM   #750
palmito's Avatar
Thank you so much, this would have saved a couple of PCB's lives had I used them...
Tube-I-zator Professional PCBHide this!Advertise here!
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright ©1999-2017 diyAudio
