Group Buys Members group buys
Tube-I-zator Professional PCB
Old 19th September 2011, 07:35 AM   #541
albertob is offline albertob  Spain
Hello Pinocchio
I am studying the possibility of adding a tube-i-Zator my buffalo II. My setup is normal stereo.
Grateful to publish a circuit diagram and comment on how close the circuit, critical values ​​of the resistors, etc.. In short, watch a bit like what you have mounted. With their experience may provide the opportunity for novices like me to try a similar project.
Old 19th September 2011, 11:04 AM   #542
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by pinnocchio View Post
Hi Studiostevus,
I have built a dual mono Buffalo II with Tube-I-Zator output and it sounds incredible. I have no such problems on harmonics as you are stating. This is most probably due to the Tube you use. On my side, I'm using the TJ Full Music 12AX7 and they sound extremely good. I'm getting a really wide and deep stage with lots of air. Bass is tight and deep. Imaging is excellent.
I also have dual Legato 3.1 SS output but for now I prefer the Tube-I-Zator.
One thing to keep in mind is the component choice you're using... I was using PRP resistors at the beginning for Rk and R I/V and although they sounded good, when I moved to TX-2575 it was a big WOW! Output caps are also extremely important... I'm using the Clarity Cap MR series which are really good but LONG to break... I was almost getting desperate here... The Mundorf Silver Gold Oil is preferred by many but the best is the Duelund Cast PIO but are impossible to buy by the common mortal!
I will post pictures of my setup at a later time.
Ciao!
Looking forward to the photo's
Old 20th September 2011, 04:04 AM   #543
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Here's a few pics of the Dual Mono Buffalo II and Tube-I-Zator
The hookup is NOT final. It is still a "prototype" but sounds amazing already!
I'm currently using TX-2575 resistors (see near tubes) and R I/V is currently set to 56R. Russ from TwistedPear Audio suggested I try 28R - 32R which I will.
I will post hookup diagrams this week for people interested.
Ciao!
Old 20th September 2011, 05:42 AM   #544
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Looks so sweet...
Very nice work !!! Keep going on
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 20th September 2011, 06:49 AM   #545
Great!, Looks very good.
What valve is used?
Can you compare the sound with the legato?
Hoping these diagrams, thanks
Old 20th September 2011, 06:55 AM   #546
What valve is used?
upss!
Old 20th September 2011, 08:50 AM   #547
DQ828's Avatar
Ciao!
Looks great, always interested in whatever you are prepared to share. My one will eventually be the cheaper stereo version, unless the obsession grows stronger from seeing your project
Old 20th September 2011, 12:10 PM   #548
pinnocchio's Avatar
Thanks to all for the nice comments!
I'm planning the following upgrades soon.
1 - Change the filtering Caps from 220uF 450V to 470uF 450V
2 - Change the Clarity Cap MR to Mundorf Silver Gold Oil
For those interested, I can sell the Clarity Cap MR for 180$ shipped for the four of them. They have about 100 hours in so they're fully "bloomed" . Never heard the Mundorf silver gold oil but at 115$ a piece I hope I will like them... I will give 4x 220uF 450V caps to the person buying this. Two of them are fully new and two have 100 hours. Those are the recommended caps in the BOM for the Tube-I-Zator.
I will keep you updated of any changes in the project!
Do
Old 20th September 2011, 12:14 PM   #549
pinnocchio's Avatar
Just a little change in the I/V resistors... It is supposed to be 21R - 32R
Sorry for the confusion!
Do
Old 20th September 2011, 12:57 PM   #550
Tfan69 is offline Tfan69  Italy
Tfan69's Avatar
if you have room i suggest you to use a CLC filter instead of crc, use a cheap hammond 9H 40mA between the two filtering caps, way better than a resistor and cheap, 10€ here in europe
Tube-I-zator Professional PCBHide this!Advertise here!
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright ©1999-2017 diyAudio
