Group Buys Members group buys
Tube-I-zator Professional PCB
Old 21st October 2010, 02:34 PM   #241
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Tube-I-zator Pre-Orders:
Cris H. - 1x (please change to your nickname yourself!)
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
HV-Shunt Module Pre-Order for 2nd Batch:
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous 2x
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 21st October 2010, 02:58 PM   #242
joemana is offline joemana  United States
[QUOTE=dvb-projekt;2339317]
It must be stable ~170VDC if you come from a 150VAC tap of your transformer.
Oliver,
Is it okay if I have 220VDC or do I have to reduce it first to 170VDV ? Also, may I know the resistor value of your RK and I/V on your Tube-I-Zator.
Thanks,
Joe
Old 21st October 2010, 04:01 PM   #243
[QUOTE=joemana;2339612]
Oliver,
Thanks,
Joe
Hi Joe,
you must measure the input voltage with the reg. (~35mA load).
If you have with the load 220VDC input voltage, i think you must use a bigger sink!
The resistor values for a 6N2P/12AX7 is Rk=200R.
The R I/V depends on the DAC Chip you would like to use. If it is the TDA1541A i would recommend 56R with one DAC Chip.
Old 21st October 2010, 04:30 PM   #244
[QUOTE=dvb-projekt;2339683]
Oliver, thank you much for your help.
I'll just reduce the B1 voltage with resistor as I don't want to change the heat sink size. What is the minimum input voltage for the HV shunt?
I have the Buffalo II DAC. I'll check the older thread, maybe a couple of Buf II owner/posters mentioned what R I/V value they are using.
Thanks,
Joe
Old 21st October 2010, 05:51 PM   #245
[QUOTE=joemana;2339703]
Thanks,
Joe
Salas recommend a Vin/Vout diff. of minimum 15-20V.
Old 22nd October 2010, 09:28 AM   #246
AutoClassA is offline AutoClassA  Ireland
Banned
Default Shippin
As it stood in the post before:
Tube-I-zator: $30
HV-Shunt Module: $14
Europe shipping: $5
paypal fee 3.9%: $1,91
Total: $50,91
That 50US$ dosent include the shipping cost?
Please inform me
Old 22nd October 2010, 09:29 AM   #247
Banned
Default Shippin
Tube-I-zator: $30
Europe shipping: $5
Total: $50,91
Sorry, Shipping to Irland
Old 23rd October 2010, 08:48 AM   #248
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
Crusty 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous 2x
Old 23rd October 2010, 02:03 PM   #249
ksnider1 is offline ksnider1  United States
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 - 1x
morpheous - 1x
neoinc - 1x
Crusty - 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
Old 23rd October 2010, 04:54 PM   #250
Anybody have a clue on why I'm getting (s/b 170Vdc) 220Vdc at B+ while my secondary is only (rated 150V and measured 150V at the terminal before the bridge rectifier) 150Vac?
All components on the board are the suggested parts.
Tube-I-zator Professional PCBHide this!Advertise here!
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright ©1999-2017 diyAudio
