Group Buys Members group buys
Tube-I-zator Professional PCB
Old 13th May 2010, 12:32 AM   #131
joemana is offline joemana  United States
[QUOTE=dvb-projekt;
have you adjust the heater voltage to 6,3V at the measuring point on the left side from the heaterswitch?[/QUOTE]
Hi Oliver,
I used it at 12.6V maybe that is the reason why. I'll adjust it to 6.3V and will try if that will fix the problem.
Thanks,
Joe
Old 13th May 2010, 07:47 AM   #132
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by joemana View Post
Hi Oliver,
I used it at 12.6V
So the heaters runs at 200%... I hope you dont damaged your tubes.
If you still have these pops, try to change the tubes to new ones.
Best,
Oliver
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 15th May 2010, 01:54 AM   #133
[QUOTE=dvb-projekt;2185577]:
Hi Oliver,
The tubes are still working. I will find out tommorow if it will make the loud pop. I'll be recieving the 6n6p soon and I might stick to that due to low gain.
Right now I don't have the switch or jumper, once I replace the tube with 6N6P, do I need to put the jumper on the 6N2P trace side or just leave it open?
Thanks for your help.
Joe
Old 15th May 2010, 06:45 AM   #134
Hi Joe,
if you use the 6N6P you must close the jumper (switch set to 6N2P)!
Best,
Oliver
Old 18th May 2010, 10:22 PM   #135
toufu is offline toufu  United States
Hi Oliver, are you going to have more boards soon? By the way, would it be possible to make the tube socket holes a bit larger for the sockets with larger leads? Thanks!
Old 19th May 2010, 05:18 AM   #136
Hi toufu,
the next boards are in production, so yes!
Ill keep your wish about the holes in my mint for a next revision.
Oliver
Old 19th May 2010, 11:15 AM   #137
Pilsern is offline Pilsern  Norway
Hi Oliver,
Thanks for the PCB.
How crucial is the voltage rating on the capacitors in tha anode supply?
Can i use capacitors rated 385 V or 400 V in the 220uf/450V spot?
What about the output capacitors? is 250 V sufficient?
Thanks again,
Pilsern
Old 19th May 2010, 05:07 PM   #138
Hi Pilsern,
i would recommend around 2* B+ (under normal load) for the output caps.
Same to the caps in the anode supply. Than youre on the absolute save side.
Oliver
Old 19th May 2010, 05:23 PM   #139
srinath is offline srinath  United States
Hey,
This board is to do a tube output stage out of a TDA1541 dac ? Can I use it on a Toshiba TC9237BN dac ? how to modify it for that.
Thanks.
Srinath.
Old 19th May 2010, 06:13 PM   #140
Originally Posted by srinath View Post
Hey,
Yes!
I dont know this DAC Chip, but why not.
Perhaps someone else can help?
Tube-I-zator Professional PCBHide this!Advertise here!
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright ©1999-2017 diyAudio
