Tube-I-zator Professional PCB - Page 79 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 25th March 2013, 08:28 AM   #781
dvb projekt's Avatar
Originally Posted by neda View Post
Hi Oliver,
When using 2 Red Baron's in parallel, are 8.2nf caps used for this mod, and
does the 28r I/V resistors (Tube-i-zator) need to be changed?
Best regards,
Ned
Hi Ned,
for the corner frequency between 300-400 kHz you have to calculate the capacitor value for one chip (56R, 8,2pF). Then place this value on each chip for each channel.
Same for the I/V resistor, simply calculate I/V resistor value for one DAC chip (=56R) and place two of these resistors in parallel (=28R).
In short, total capacitance is doubled, total I/V resistor value is halved, turnover frequency remains unchanged.
When using two Red Baron parallel, you need 4x 8,2nF caps and a R I/V of 28R.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 26th March 2013, 05:22 PM   #782
Exclamation Personal announcement
Well my friends it is time again to say thanks to all of you, who like and ordered my pcbs.
Because i am no developer of electronic circuits but have the knowledge to design pcbs,
i wanted to give something back to the community.
Since i started with my 1st pcb, the Optical-Volume-Control on 15th October 2009,
a small donation from every sold pcb goes to diyaudio.com
Today i am proud to say that your cumulated donation achieve
$ 3104
Keep on having fun with my pcbs and best regards
Oliver
Old 1st April 2013, 12:46 PM   #783
Exclamation Bargain Sale
Bargain Sale
Here you could order my ready build Tube-I-zator test module
(excl. Tubes, Rk & R I/V)
Main Parts
- Nichicon KX Series caps (HV-PSU)
- Panasonic FM Series caps (Heater PSU)
- Mundorf MCap EVO aluminium/oil 2.2F output caps
- Fairchild ISL9R460PF2 Stealth rectifier diodes
for the special price of
$99
including
Worldwide shipping and paypal fee
If you are interested, please send me a PM.
Old 5th April 2013, 03:29 PM   #784
Exclamation The new Tube-I-zator V3.0
The evolution brings the following changes:
- Anode PSU with Salas SSHV Shunt Reg. onboard
- External B+ Input for usage with other Anode PSU
- Heater PSU with C-R-C filtering
- Heater PSU with Softstart circuit
- Heater PSU Power LED
Thanks to John (-ecdesigns-) for the following suggestions!
- Grid stoppers to prevent unwanted oscillations
- Bias current injection for TDA1541A usage
- Pull-down resistors to keep the coupling cap output at GND-potential
Still on the Module:
- Heater switch for 6N2P or 12AX7 usage
An example for a balanced use (e.g. Bufalo II), you could see HERE.
The PCB has the following data:
Material: FR4 - 2mm
Layers: 2
Board size: 193x157 mm
Surface finish: Immersion Gold
Copper weight: 70m
Soldermask: Both sides - green
Silkscreen: Legend on top
In Stock
The price will be as followed:
Professional 2-Layer PCB: $30
Worldwide shipping: $ 9
Europe shipping: $ 5
paypal fee: 3,9%
Shipping insurance on buyers request!
A donation of $3 USD to diyAudio will be done for every pcb sold.
A 2nd small failure in my design program needs to expand one of every heatsink mounting holes a bit (1mm).
These two small design failures will be corrected in one of the next batches.
Thanks in advance for your understanding!
You will find the BOM and Schematic in my blog.
Old 5th April 2013, 03:38 PM   #785
Attached two quick pictures of the populated Tube-I-zator V3.0
Old 5th April 2013, 04:01 PM   #786
Nice work Oliver!
Old 5th April 2013, 08:23 PM   #787
Hi.
Can i use Tube-I-zator PCB with PCM1794A? (DDAC 1797 NOS -Doede)
Old 5th April 2013, 08:36 PM   #788
merlin2069er's Avatar
Send a message via MSN to merlin2069er
neat.
Old 6th April 2013, 09:47 AM   #789
Originally Posted by crobbins5421 View Post
Nice work Oliver!
Originally Posted by merlin2069er View Post
neat.
Originally Posted by jeremysk View Post
Hi.
Sure. Please ask Doede witch I/V resistor value , Tubes and Rk value he recommend.
Old 8th April 2013, 12:26 PM   #790
acccruz is offline acccruz  Portugal
Nice work Dear Oliver!
CONGRATULATIONS!
Soon I will buy one or may be two boards.
Antonio
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright 1999-2017 diyAudio
