Tube-I-zator Professional PCB - Page 72 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 19th June 2012, 11:59 AM   #711
pinnocchio's Avatar
Originally Posted by DQ828 View Post
pinnocchio
I thought the second secondary had to be 9v?
It is better yes for bom components but i have changed the 3 filtering caps for filament to 25v instead of 16v and added a larger heatsink on the regulator. The 12v are paralleled for more current.
You can always use a separate transfo if you're worried.
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 4th July 2012, 11:31 AM   #712
DQ828 is offline DQ828  Australia
DQ828's Avatar
Default Transformer Dilemma
I have not been making any progress because the local supplier has bee slow in giving me a price to make the transformer. He has advised me I require the following transformer to ensure I get the best performance,
Will design on a 120VA Core at 0.5Telsa, with an Electrostatic Screen and Flux Band 1 x 150v @ 0.1A & 9V @ 2A
The cost is $166.00 plus freight!!! & he wont be able to make it for 3 or so weeks!!
Do I really need this fancy transformer? Will it make a difference, say to the type ANTEK sell?
Old 4th July 2012, 11:35 AM   #713
pinnocchio's Avatar
I'm on the same page here... You're wasting your time and maybe money here... Get the Antek transfo and use the SSHV 1 that Oliver sells or the SSHV2 or any other nice HV shunt.
I'm currently using the SSHV2
The Antek transfo works perfectly and does not vibrate or hum. You really should consider it
Ciao!
Do
Old 14th July 2012, 12:21 PM   #714
DQ828's Avatar
I have ended up ordering the local transformer because I was advised by Antek that they "Didn't make or modify transformers"
I have been getting up the courage to order some Texas TX2575 resistors, I was wondering what tolerance should I order?
David
Old 15th July 2012, 04:52 PM   #715
dvb projekt's Avatar
David
Hi David,
i am using the 0,1% tol. TX-2575. Just send an email to Arbie Lopez with regards from me
Oliver
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 16th July 2012, 08:42 AM   #716
DQ828's Avatar
What value are you using at the cost of these thing's I'm not keen on buying a whole bunch that won't get used.
Old 16th July 2012, 10:23 AM   #717
I ended up using 29R value for the R I/V. Sounds better to me than the 39R I had before. Better dynamics and resolution, IMO. The value can vary depending on the DAC you are using however. I am using the Buffalo II DAC.
Greg
Old 17th July 2012, 11:53 AM   #718
DQ828's Avatar
Greg
It takes a brave (or lazy) man to ask this question What do the I/V resistors actually do
Well I have ordered 26 & 32 ohms pot luck really
Old 27th July 2012, 09:34 AM   #719
DQ828's Avatar
don't tell me no one knows the answer
And why does the quality matter?
Old 27th July 2012, 09:39 AM   #720
DQ828's Avatar
I finally got the transformer, ended up going the whole hog, has screened windings & a flux band, it is also built on a larger core to keep the TESLA value down, if only I knew why
Peter (the maker)said I wont be making another one that cheaply again Mind you $180.00 didn't seem cheap to me.
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright 1999-2017 diyAudio
