Tube-I-zator Professional PCB - Page 26 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 23rd October 2010, 08:14 PM   #251
Oliver,
Could you please add my name for two pcbs for the HV shunt regulator.
Thanks,
Igor
Old 23rd October 2010, 08:41 PM   #252
dvb projekt's Avatar
Tube-I-zator Pre-Orders:
Cris H. - 1x (please change to your nickname yourself!)
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 - 1x
morpheous - 1x
neoinc - 1x
Crusty - 1x
HV-Shunt Module Pre-Order for 2nd Batch:
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
ipolyakov - 2x
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 23rd October 2010, 08:42 PM   #253
Originally Posted by joemana View Post
Anybody have a clue on why I'm getting (s/b 170Vdc) 220Vdc at B+ while my secondary is only (rated 150V and measured 150V at the terminal before the bridge rectifier) 150Vac?
All components on the board are the suggested parts.
What is the load (mA) for your 220VDC measurement?
Old 23rd October 2010, 10:39 PM   #254
joemana is offline joemana  United States
Oliver,
The measured 220V is without the load. I also tried just after the rectifier, it's also 220V.
Thanks,
Joe
Old 24th October 2010, 03:51 PM   #255
Oliver,
Thanks,
Joe
Hi Joe,
your values are absolute normal and correct.
As you see on the following snapshot from the PSU Designer, there are the same values.
If i add the ~35mA load from the shunt, the voltage drops to the recommended 170VDC input voltage.
Best regards,
Oliver
Old 25th October 2010, 09:32 PM   #256
Tfan69 is offline Tfan69  Italy
Tfan69's Avatar
Hello Oliver, there is a preferred point to get the ground line on the tubeizator to be connected to the star ground of the chassis? how do you ground yours?
thanks
Old 26th October 2010, 05:58 AM   #257
savvas is online now savvas  Greece
Add 2 shunts for me so:
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
ipolyakov - 2x
savvas - 2x
Old 26th October 2010, 06:22 AM   #258
thanks
Just connect one of the GND contacts to the star ground.
Old 26th October 2010, 06:23 AM   #259
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 - 1x
morpheous - 1x
neoinc - 1x
Crusty - 1x
Jean-Charles - 2x
kamaths - 3x
bequerel - 2x
morpheous - 2x
ksnider1 - 1x
ipolyakov - 2x
savvas - 2x
Old 29th October 2010, 01:41 PM   #260
Tfan69's Avatar
Hello Oliver,
i have a strange behaviour of the shunt: it is supposed that i have a Vin and a Vout, let's say that i have 240v Vin, if i adjust the trimmer to have Vout=220 the Vin drops down and Vout is always approx Vin-2v
any ideas?
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 02:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 04:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 05:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 09:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 11:06 AM
Copyright 1999-2017 diyAudio
