Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 20th October 2010, 09:55 AM   #231
Banned
Default adding me
Originally Posted by dvb-projekt View Post
Sure. Add yourself into the list below.
Tube-I-zator Pre-Orders:
Cris H. - 1x (please change to your nickname yourself!)
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
HV-Shunt Module Pre-Order for 2nd Batch:
Jean-Charles - 1x
kamaths - 3x
bequerel - 2x
Please tel me how to add here???
Also what payment u accept for ?
Old 20th October 2010, 11:49 AM   #232
morpheous's Avatar
Send a message via Yahoo to morpheous
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
Jean-Charles - 1x
kamaths - 3x
bequerel - 2x
morpheous 2x
Old 20th October 2010, 01:32 PM   #233
dvb-projekt's Avatar
Send a message via Skype™ to dvb-projekt
Witch and how many pcb´s do you like to pre order?
I add you on the list. Before the production starts, you get a paypal invoice from me.
Best regards,
Oliver
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog
Old 20th October 2010, 05:26 PM   #234
joemana is offline joemana  United States
Oliver,
I recieved the boards, thank you.
Can you please give us (tube illitirate) some pointers on HOW to go about with this upgrade.
1.Once I completed the board, what should I check first before I hook it up to the Lampizator? When do I need to adjust the pot?
2.If I will use 12AX7 or 6N6P tube, what will be value of resistor in place of 56R resistor? How to do the computation or reference?
3. What else do I need to change?
Thanks,
Joe
Old 20th October 2010, 10:18 PM   #235
Banned
Best regards,
Oliver
OK, That sounds good.
I need to knowing the price for that PCB.
Please why I cant see my posts? it take too much time to appear
Old 21st October 2010, 07:06 AM   #236
Originally Posted by joemana View Post
Oliver,
Thanks,
Joe
Hi Joe,
after dissoldering the TB1 & TB2 bridges, connect the HV-Shunt to the TB1 input of the Tube-I-zator and measure the input voltage.
It must be stable ~170VDC if you come from a 150VAC tap of your transformer.
If that´s ok, connect the output of the HV-Shunt to the TB1 output tap of the Tube-I-zator pcb as on my photos
(don´t forget to bridge the TB1 & TB2 output tap´s).
Then measure the B+ output voltage of the HV-Shunt and set it with the pot to 150-155VDC. That´s it.
The 12AX7 has the same resistor values as the 6N2P.
For the 6N6P (6H6) Lucas Fikus recommend also the same B+, Rk & R I/V values.
I myself don´t try this one.
Old 21st October 2010, 07:22 AM   #237
Exclamation New Tube-I-zator price
To get a uniformly donation for all my PCB´s,
also the Tube-I-zator price get´s the $3 donation for diyaudio.
The consequence is, that the Tube-I-zator price drops to
$30
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
Jean-Charles - 1x
kamaths - 3x
bequerel - 2x
morpheous 2x
The price for the HV-Salas Shunt reg. module is $14.
Old 21st October 2010, 10:27 AM   #238
Banned
Default PCB
Best regards,
Oliver
I think I will need one of each PCBs.
Price please
Old 21st October 2010, 11:24 AM   #239
Price please
As it stood in the post before:
Tube-I-zator: $30
HV-Shunt Module: $14
Europe shipping: $5
paypal fee 3.9%: $1,91
Total: $50,91
Old 21st October 2010, 02:18 PM   #240
Oliver,
Would you add one more pcb for the HV shunt regulator.
It should read now: Jean-Charles 2X
I don't know how to edit the Forum properly at the risk of damaging something.
Thank you
STK Professional V-6 Amp--need schematics wcarthur Instruments and Amps 0 21st April 2009 01:59 PM
I need a professional opinion... sparky3489 Car Audio 0 25th June 2006 03:31 AM
professional opinion rv1890 Multi-Way 2 12th January 2005 04:22 PM
Professional Anodizing - How to? tiroth Everything Else 20 30th January 2004 08:15 PM
Anyone tried Professional DIY PHILIPS CD kit ??? till Digital Source 6 4th June 2002 10:06 AM
Copyright ©1999-2013 diyAudio
