Group buy: alexw88 PA150, BPA300 project together with DRV134 pcb - Page 8 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 12th April 2010, 02:01 PM   #71
Electrons are yellow and more is better!
peranders's Avatar
The pads are clean enough but I think this is about soldering temperature and soldering time. The pcb has thick copper.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 12th April 2010, 02:42 PM   #72
That could be quite possible as I am a little new to diy audio, with this being the second main project.
What temperature would you recommend I set the soldering Iron too for best results?
Old 12th April 2010, 05:01 PM   #73
peranders's Avatar
You can use up to 450 deg C for those parts that are connected to the groundplane. 350-400 deg C is normal I should think.
Old 12th April 2010, 11:21 PM   #74
Ok I had it set to 360 deg C.. So I will try again with the temperature increased and see if that solves my problems..
Old 23rd April 2010, 07:52 PM   #75
peranders's Avatar
Four pcb kits are left.....
Old 27th May 2010, 07:26 PM   #76
peranders's Avatar
1.5 kits left = 6 pcs. PA150 pcb's.
Old 31st May 2010, 05:31 AM   #77
peranders's Avatar
2 pcb's left.
If there is any interest for more boards I'll consider a new group buy after the summer.
Old 6th August 2010, 05:08 PM   #78
lloop9 is offline lloop9  Singapore
Hi Peranders, I would be interested in 4 pc of PA150 if you're going ahead with a new GB. Thanks.
Old 9th August 2010, 08:45 PM   #79
Hello,
I have a question regarding the filter caps on the backside of the pa150 pcb. am i connecting one cap between pins 4 and 7, and the other cap between pins 5 and 7. (7 being ground, 4=V- and 5=V+)
What about pin 1, which is also V+?
I've tried following shine7.com (alexw88) pa150 backside photo but the caps cover the connections in question. I also looked at this photo, which doesn't seem to have the same connections:
http://www.diyaudio.com/forums/attac...0-backside.jpg
if anyone could point me in the right direction I'd greatly appreciate it
Old 10th August 2010, 07:54 AM   #80
peranders's Avatar
Group Buy: DRV134 pcb, unbalanced to balanced peranders Group Buys 84 11th January 2011 12:01 AM
BPA300 PCB Group Buy rhysh Group Buys 210 27th March 2009 04:06 PM
Upgrade Alexw88's BPA300 desighn?? madam Chip Amps 3 3rd January 2009 11:01 AM
FS: BPA300 PCB incl DRV134's Mayday Swap Meet 11 5th April 2007 12:39 PM
Copyright ©1999-2017 diyAudio
