Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 15th March 2010, 03:49 PM   #151
dbengt is offline dbengt  Sweden
Algar_emi,
if you make new ones would you please pm me? I'd like a couple but it looks like I am late. If you have decided not to sell more would you share your PCB design file so that I could order from some company?
Old 23rd March 2010, 11:33 AM   #152
Sorry for the bump, but ...
I was wondering how good the PSU needs to be before the regulator ? I was planning a tube rectified LC filter, but that may be overkill, and should probably save that for a power amp, or something.
Would a schottky rectifier with an RC filter suffice ? PSUD shows about 5V ripple like that. CLC gives 0.3V ripple.
Old 2nd November 2010, 10:57 AM   #153
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I got a request for the latest document recently. Here it is.
http://www.basaudio.net/datasheets/hvreg.pdf
Old 3rd November 2010, 04:26 AM   #154
Thanks Bas , much appreciated !
Old 3rd November 2010, 04:44 AM   #155
Default Question Re: Parts and Sources
I've been searching for .5 Watt resistors with 7mm bodies and .25Watt R's that are 4mm as listed in the assembly manual . I'm not 100% sure I am using the Digikey parametric search the best way but so far I can't find the listed values in anywhere close to those sizes. If anyone has already tracked them down and still has their list on the desktop would you post? It would help me a lot.
Also, are the Os Con caps made by Vishay pretty much the same animal as those by Sanyo?
HV Shunt Regulator PCB Algar_emi Group Buys 238 23rd May 2012 08:57 PM
Shunt regulator tubee Tubes / Valves 12 2nd March 2006 01:08 PM
Page generated in 0.07934 seconds (69.20% PHP - 30.80% MySQL) with 11 queries
