Group Buys Members group buys
NEW Silonex LDRs for Lightspeed Attenuator
Old 15th January 2010, 11:35 PM   #151
NicMac is offline NicMac  Italy
NicMac's Avatar
Yes - I understood it that way.
Maybe a better title would be "BOM and components".
Sorry,
Nic
Old 15th January 2010, 11:51 PM   #152
udailey is offline udailey  United States
Passive Aggressive
Nic,
You are right. Thats a much better title. I still need to use LDR Controller Board in the title but I think you steer me in the right direction. I used the title I did because it was short and I couldnt think of a way to say it otherwise that would not be long. If you read most of my posts you will see brevity is not my strong point. You, however, have a good point. It will be done!
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 17th February 2010, 05:39 PM   #153
Spooky Electric is offline Spooky Electric  Germany
Spooky Electric's Avatar
Default Dark Helmet's Ludicrous Speed Attenuator
LDRs arrived in perfect condition. Thanks!
Old 17th February 2010, 05:42 PM   #154
Bas Horneman is online now Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Mine too...thanks!
Old 10th March 2010, 09:02 PM   #155
bikerboy is offline bikerboy  United States
Default Lighter Note lives
Thanks to Uriah I have a new pre amp to play with. I just completed it this am. Listened to it for a couple of songs before I had to go to work. It sounds very good, open with good tight bass. Its just on a board to work out the layout. I am using it with a TPA Buffalo24 and a Jolida sj-502 that I removed the passive volume control, balance, and input switching. I need to understand how to optimise the impedence for both. I think the amp is high (45K) but dont know about the dac. I would like to make a wireless remote for the volume only. I ordered relays last week so I'll see if I can make those work to switch 3 inputs. I dont need that to switch on a remote. Cant wait to get home and really listen to it tonight. Thanks again Uriah for the well made kit.
Old 10th March 2010, 09:09 PM   #156
Passive Aggressive
Thanks so much for your post.
If you have suggestions for how I can improve the instructions I posted online please email me. I know some have found them confusing and I dont want that to be the case. I think I talk to much sometimes when I am explaining.
Anyway! I am really happy that you like it. So you have a 45k amp? I do to. 47k. I like a 6k setting on my Lighter Note with my <50R output source. A dual gang 1k pot will give you somewhere around this. But sometimes listening is better than tinkering.
Uriah
Old 11th March 2010, 06:59 AM   #157
Default Lighter Note is very heavy!
Listening to The Beastie Boys -The Mix Up. WoW. Super big bass, scary quiet backround. Imaging is very cool with the SDA polks. Just what the TPA dac needed. This pre is so very calm and detailed. As far as the insructions go, I was confused that the M and B ldr board was at the end. Not clear if setting the hi (95R) on both the series and shunt was the best to do but thats what I did. I must say I dont understand this impedence thing well. But this sounds good! Bettye LaVette-The Scene of the Crime next. Thanks Uriah.
Old 11th March 2010, 01:21 PM   #158
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
Man, I got to compare my Aunt Corey against Uriah's LDR attenuator (pre - Lighter Note) at his place in Houston. We both enjoyed the warmth of my Aunt Corey, but Uriah's attenuator really shined in the mids and the highs compared to old Aunt Corey. So Uriah calls me later and he starts telling me what he is cooking up. After he built the Lighter Note proto, he tells me that it smokes his previous version. So bikerboy, thanks for giving your impressions. I think it is almost time to send Aunt Corey to the retirement home!
Old 11th March 2010, 01:45 PM   #159
Passive Aggressive
Biker,
Try using the Shunt LDR Controller Board to dial down the shunt resistance to 40-50R. P3 will help with that. So just put your DMM across output and ground. Then dial P3 until you get something in that range. Do this without the RCA cables connected. This will allow the minimum volume to be lower. Dont worry about series, you probably will never turn it up to 95R or lower on series anyway.
Uriah
Old 11th March 2010, 01:49 PM   #160
Passive Aggressive
Biker,
If you can not dial down lower than 95 then short out the 68R resistors on the M and B board with the volume pot at midway. Then as you dial down the volume pot the shunt resistance will begin to drop. When it gets down to 40 then use P3 and dial it up to 80 or something like that and continue to dial down the volume til you get to 40 then use P3 to dial it back to 80, etc....
Once you get to min volume you can safely use P3 to dial in exactly the minimum resistance you want, but no lower than 40R please. Why do we do it in this complicated way? Because without 68R in place the LDRs are in danger of getting to much current and frying. With a DMM and this procedure we can always make sure we dont let them get in danger.
Uriah
NEW Silonex LDRs for Lightspeed AttenuatorHide this!Advertise here!
Silonex LDRs for Lightspeed Attenuator udailey Group Buys 445 3rd March 2011 07:26 AM
