| Group Buys Members group buys |
#941 | |
diyAudio Chief Moderator
P.S. Here are the pads and the routing, as well as a typical 27mm Alps blue. |
#942 |
And the actual boards. (Doh!)
#943 |
...truth seeker...
I've just added my interest to this effort on the Gxxgle list.
Have completed a quick read of the thread. What a ride you have been on! Congratulations for your patience and persistence. Looking forward to $ending the money.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#944 |
I just place my name in the WIKI for the group buy.
Could not find the above info Thanks for the great work kp93300 |
#945 | |
not politcally affiliated
I may not be thinking this through, but I assume that the pot just may face the other direction. A 180 degree shift on the board. Doesn't that solve the problem?
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
#946 |
Yes it does if he thought about an extention rod, since that ties with the front face DCB1 blah blah also. Our front is his back?
![]() ![]() Don't know what he had in mind though. He just said, ''tested with a pot, no problemo''.
#947 |
wombat
I wasn't sure what was intended with the pot and simply connected it the way it seemed to make sense from looking at the traces on the pcb.
#948 |
OK we found a logical explanation. The board goes near the back for close wiring to IN/OUT and the pot looks with its shaft towards the board's inside. So when the front of the box faces it, the legends read correct. That is why he left an open corridor. OK, Indiana, errr, Tea - Bag, deciphered that.
Tell me now why no chatter on Omron 12V too?
#949 | |
halo -about Pot. i have checked. compare to Fred design nothing wrong (just rotate 180 degree my version, and you get a same pinout) ??? -for LED position, i have fix it. i hope you like it (see attachment) just tell me if something wrong. Regards La Ode |
#950 |
Forwarding to Tea-Bag
