| Group Buys Members group buys |
#2391 |
#2392 |
Can I substitute the bipolar transistors with different models?
For example the BC550/560 ones with 2n3906/2n3904? Maybe something for the BC-517 as well? Not that they're hard to find or anything, but I've a huge box of transistor soup here - 2n3XX, 2n5XX, A, S, C - all kinds of prefixes basically and if I can use them already, I don't see why not. I guess finding replacements for the relay drivers isn't a problem, but what about the ones in the regulator itself? |
#2393 |
the FET driver needs medium speed (fT~200MHz) and highish gain (hFE>300).
The relay driver needs medium Ic (>100mA) and good gain at high current (>200 @ 5mA) hFE>150 @10mA and 20mA saturated @ Ic/Ib>10 for 0.1Vce. If using a 5V relay, then maybe Ic>150mA, 40mA sat @ Ic/Ib>10 for 0.1Vce. But, watch all the different pin outs. |
#2394 |
not politcally affiliated
Salas and I are going to attempt to re-issue some Mesmerizes. We looking for at least 50 units to sell.
Figured that this won't directly interfere with Blue Edition demand, so it's a good time to offer it. Some people really liked this gadget because of it's relay switched inputs. We are going to open a potential group buy sheet for a couple of weeks to see if there is real interest. The price would be 14.00 dollars, a single sided board, and would use 2 oz copper instead of 1. Here is a blurry pic of my original DCB1 Mesmerize. Here is the sign up sheet. https://spreadsheets.google.com/ccc?...DeHBDamc&hl=en
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE Last edited by Tea-Bag; 31st August 2010 at 05:04 PM. Reason: added sign up sheet. |
#2395 | ||
This is actually worrying me more than going trough the datasheets for electrical characteristics. I'll end up getting 1 transistor the wrong way, because I forgot it's using a different pinout, sooner or later ![]() Thanks AndrewT, that's a lot of help, as usual. |
#2396 |
As usual... I'm late to the party! I've spent the past 8 months building my long-awaited Aleph-X amps and open baffle speakers, and I miss all of the action for a nice preamp. Anything left for me to buy to get in on the action?
Eric
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages. |
#2397 |
Will the new Mezmerize board have the beefed up power supply of the Blue Hypno?
#2398 |
will it incorporate the remote sense as adopted for all the later versions?
will it include a better relay delay/driver? will it wire in the delay relay properly? |
#2399 |
diyAudio Chief Moderator
No, its not a redesign, just a better quality pcb reissue. There were some voices about missing the Mez full pre, so we thought we can try out and see if there will be some minimum interest in signing up for it. It was something we promised earlier in this thread. That one is not normally being gauged for a reg only heavier use, so its psu is adequate for uF.
#2400 | |
Crt is not around to make any tweaks, its the old Mez. |
