| Group Buys Members group buys |
#1001 | |
diyAudio Chief Moderator
#1002 | |
![]() =GB= |
#1003 |
Glad to hear you are up and running. Even better to hear my impressions confirmed by another listener! It really is amazing.
#1004 |
But maybe a silly idea. OK I shut up. |
#1005 |
PCB was in the mailbox this afternoon when I got home from work
Some progress was made as far as filling the board. Tomorrow I may get it hooked up with some music.It is obvious that crt has layed out more than a few PCB's in his time, and has his preferences for pad and hole sizes. The quality is good. It is well laid out and this makes it easy to build. I hurried it up a bit so I could get back to you guys who are waiting on the last of the proto builders, so a decision on a go-ahead for PCB production can be made soon. I remember Salas saying something about LED sizes, now I understand, 5mm LED's will not fit flat on the PCB. No relay chatter, it turns on after about 3 to 4 seconds, the part number of the one I am using is GP-212 and the manufacturer is Goodsky. I am not using an LED in the cct near the timing cct for the relay yet. I put a 100nF cap in the cap position next to the LM7812, i.e. the unmarked cap on the input to the LM7812, and the LM7812 manufacturer is STI. The AC input from the 60VA 15-0-15 tranny is 16.5 and 17.4V, the DC out from the rectifier is 23.8 and 23.6, the regulated DC is -9.74 and +10.04, the DC offsets are -1.1mV and -0.5mV. Hope this info helps. Time to eat and go to bed now... http://i198.photobucket.com/albums/a...60/Buffer1.jpg http://i198.photobucket.com/albums/a...60/Buffer2.jpg Last edited by Ian444; 29th September 2009 at 01:38 PM. |
#1006 |
not politcally affiliated
Any of the proto builders going to Burning Amp? I plan on going, but not sure I can cobble this into a box in a week. Thought we might try a demo of it if possible.
SemiSouth R085/R100A JFET available now DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE |
#1007 |
Is there any positive feedback from the relay drive to the control signal input?
As the transistor starts to send current through the relay the positive feedback increases the speed of activation and ensures a hard switch on signal without chatter. Without feedback the signal rises slowly and if the source impedance feeding the relay is high the current falls as the relay starts to pull in and falls open again. This problem will be alleviated by using lower current, higher voltage relays. 5V need lots of current, 24V need tiny current by comparison.
regards Andrew T. |
#1008 |
Have we moved from the google spreadsheet to the new wiki system here?
Fran |
#1009 | |
I think Tea Bag also can try changing his 7812 to check this out. kannan |
#1010 |
kannan - that't great news. Mine was off the Mouser BOM provided.
| Page generated in 0.15663 seconds (48.37% PHP - 51.63% MySQL) with 11 queries |
