Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 26th February 2010, 09:33 PM   #131
I might be offering these Keratherm to everyone.
Price will be close to the price here (at least for TO-247), provided you get at least 50 pcs.
For TO-220, there is two type:
one is the type here: 18mm x 12mm
another is: 19mm x 14mm
FYI, a typical TO-220 chip is 15x10, so the bigger one offers 2mm per edge, which might be very useful if you use non-insulating thermal grease like arctic silver
The difference of cost is about 5-10 cents.
For TO-247 I think the 32x23 size here is very good and I will stick to it.
For uncut sheet, there is a 34mm x 27mm square sheet without any hole, which is plenty to cover any common package.
I think pads without hole will be good for clip mounting (rather than screw mounting), especially if you want to use conductive thermal grease.
Due to the lower volume I expect, and the larger size, the cost is expected to be between 150%-200% that of the 32x23 TO-247.
Let me know which TO-220 size you prefer, and what do you think about the 34x27 sheet without hole.
Old 26th February 2010, 09:52 PM   #132
tinitus is offline tinitus  Europe
If this keratherm works as promised, I would expect it to loose its advantage if you use thermal grease
non-insulating arctic silver ?
sounds dangerous to me
could it make short connection through the hole at mounting screw ?
But I would still be interested in raw uncut sheets, in a size that fits into an envelope
But not an option, I suppose
Old 27th February 2010, 06:20 AM   #133
EUVL is offline EUVL  Europe
You miss the point completely. The stuff requires NO grease, just like Silpad.
But unlike Silpad, or mica with Whatever grease, it has a maximum temperature difference of 5°C at 30W dissipation on a TO247/TO3P.
I have been using the stuff for years (since 2006), have measured enough examples in enough different applications myself.
I am also the one who made it know to the Pass forum.
So the stuff works, as long as you use it properly, like NO grease.
See :
Mica and Goop
Even the fragility of the foil is public since 2006 !!
Patrick
PS You can get A4 sized uncut sheets (which is what I use) if you buy enough. But you need ceramic scissors to cut them properly. Or at least use a brand new one which will be no good for anything else after finishing one A4 sheet. The foil is ceramic powders embedded in plastic matrix.
Old 27th February 2010, 06:53 AM   #134
A dated application from January 2007.
Patrick
PS The 4x TO247s are power film resistors and do not require additional electrical insulation.
_______
Old 27th February 2010, 09:37 AM   #135
Thanks everyone for pointing out the points.
It is good to know that grease is not needed.
Their 86/81 is without Glass fibre and I wonder it might be easier to cut.
Old 27th February 2010, 12:55 PM   #136
I should expect that you, as a respectable gentleman, would get some samples of the stuff, try it out, understand the function and the performance, before you would open a new thread to offer it to fellow DIYers, just like Marc did here (irrespective of motivation).
Best regards,
Patrick
Old 27th February 2010, 01:38 PM   #137
As already mentioned in August 2007 :
Mica and Goop
WÄRMELEITFOL.86/82 ROT 190X190X0,25 MM im Conrad Online Shop
for those who lives in continental Europe and wish to experiment.
Plus a whole variety of others :
http://www.conrad.de/ce/de/FastSearc...e&initial=true
and you do not need to buy 1000 pieces if you only want one.
Patrick
Old 27th February 2010, 03:43 PM   #138
Thank you Patrick again for your kind suggestions and the direct links!
I spend most of the time looking at various datasheets, and I admit I had yet to have a physically look at one of these.
I was assuming that since many here is using it (though the fragility), and the datasheet figure and user report all confirms the excellent thermal property, this produce should be rather good for our purpose.
I'm on my way to get some TO-247 transistors for sale, and wants to offer these isolation pad to provide some convenience for my future buyers, as I myself find it hard to get a small quantity of high performance isolation pad in a cost effective and easy way at where I live. So I do need a large quantity of these.
I fully agree with you that Marc had done an excellent service here which is beyond what an average person would, myself included for sure.
Zhou Fang
Old 3rd March 2010, 12:08 PM   #139
Is it too late to pick a few of these up? I need 8 of them for to-247 devices.
Old 11th March 2010, 07:23 PM   #140
npapp is offline npapp  United States
Hello, I am interested in a small sheet. 1x 200mmx200mm or 2 100mmx200mm sheets. Any thoughts on the price?
Patrick, I see that conrad has a sheet that fits my needs, but I don't think they ship to the US. Do you know of any other vendors selling small sheets?
Nick
Using Digital isolators instead of Opticouplers TechGuy Power Supplies 2 6th July 2008 08:58 AM
audio isolators how to mhtplsh Solid State 0 24th May 2008 01:56 AM
High-Speed Digital Isolators? Ryssen Digital Source 2 20th December 2006 07:42 PM
Pneumatic isolators Prune Everything Else 2 18th February 2004 08:55 PM
Page generated in 0.11069 seconds (80.97% PHP - 19.03% MySQL) with 11 queries
