Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 15th December 2010, 01:10 PM   #621
regiregi22's Avatar
Originally Posted by EUVL View Post
Yes they do have versions with aluminium plates, but the angles and the screws are still most likely steel (magnetic).
Is that a bad thing? I thought that steel or magnetic conductors were bad for carrying signal, didn't even imagine that having these materials near will affect.
Originally Posted by Spev View Post
Anyone running F5 with DCB1 pre? Any issues with them both being dc coupled?
Yes I do, not issues at all with DCB1's protection relay. Neither turning first the preamp on nor the poweramp.
But I have output capacitors at my source.
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 22nd December 2010, 06:00 AM   #622
reytnz is offline reytnz  New Zealand
reytnz's Avatar
Peter Daniel;2399316]This GB (3rd re-run) was just opened, so plenty of boards are available.
Hi Peter,
Recieved mine today, Thanks!!
ReytNZ
Old 27th December 2010, 02:57 PM   #623
chlorofille's Avatar
Am still waiting for the boards to arrive. Peter shipped them on 27th Nov.
Hopefully they will arrive soon. =]
Old 28th December 2010, 04:40 AM   #624
potepuh is offline potepuh  Slovenia
Hi Peter
Are there any F5 boards left?
Old 28th December 2010, 06:48 AM   #625
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Yes, plenty of boards still available.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th December 2010, 04:07 PM   #626
h_a is offline h_a  Europe
h_a's Avatar
Technically? No.
I remember Syn08 found for his ultralow distortion amps that steel made a measurable difference, but before you worry about steel in context with such amps, you need to get wiring/grounding right first. Really big topic for ultralow distortion amps.
No need to worry about that
Old 29th December 2010, 01:59 AM   #627
Kilroy is offline Kilroy  United States
Quick possibly newb question, I found some 22,000uf 35V caps for my stereo F5 project... Is 35v sufficient? I see people going up to 65v and wasn't sure if that's just a product of what was available at the time or some other meaningful reason.
I know Nelson specs 18000uf 25v... I just want to verify that's OK for this PSU design as well... I don't see anything that would cause a change but I'm a rookie.
I made smoke!
Old 29th December 2010, 02:10 AM   #628
tinitus is online now tinitus  Europe
I bet they are with good ripple ratings (current)
Old 29th December 2010, 01:06 PM   #629
Default ordering boards....
Peter, I thought I would pick up another set of F-5 boards. Do we use the info and pricing on page 1 still? seems like I remember an increase for shipping or something? Same pay pal address on the audiosector site?
Thanks,
russellc
Old 29th December 2010, 01:13 PM   #630
regiregi22's Avatar
Originally Posted by h_a View Post
Technically? No.
Thanks, quite recomforting
Kilroy, you must choose capacitor rating to be AT LEAST higher than the applied voltage. So, for a 24v supply, 25v rating would be enough. They won't explode if you apply 26v or even 28, but that will shorten their life.
Personally, I would use 35v for a 24v supply. Going higher only increases size and cost.
Regi
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
Copyright ©1999-2013 diyAudio
