F5 pcb group buy... - Page 53 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 22nd August 2010, 01:38 AM   #521
Boards arrived in the mail today Peter, thanks for all.
Russellc
Old 24th August 2010, 11:27 AM   #522
joefish is offline joefish  United Kingdom
Hi All, this is my first post although I am a long standing lurker.
Are there any F5 boards available or anyone planning on doing an F9 layout.
Old 24th August 2010, 04:04 PM   #523
chlorofille's Avatar
After a couple of email exchanges with Peter Daniels, he says he doesn't have them in stock; though no further info on when the new boards (if any) will be ready. Let's sit tight and wait patiently
Cheers~
Old 24th August 2010, 11:51 PM   #524
Cheers~
Cviller just posted he has a few up for sale, I've only built with Peter's, but many I know have also used Cviller's boards. Similarly, Tech-DIY is supposed to be offering kits soon....Peter did tell me he still had plenty of power supply boards.
russellc
Old 1st September 2010, 11:43 PM   #525
regiregi22's Avatar
I am building a pair of F5 monoblocks. Each one with a transformer, a full diode bridge for each rail, and four 22.000uF caps with the 4x 0.1r 3w each full dual rail board.
Only one quick question: Is it ok if I put jumpers as in the way shown on the attached picture? These pads will be unused, so I am guessing that placing 3 of them could be better for making a dual supply PSU. I don't think it will make a ground loop.
Power will be taken to an F5 board from the marked outputs. These are your F5 boards. There is a wire from the F5 ground pad to the marked pad on the picture. The return of the speaker will go where marked in the picture.
Can anyone give it a quick look and check if it is alright?
FYI, it will carry all caddock MK132, and Mills for the power resistors. Capacitors are Mundorf MLytic SI, Schottky TO-247 rectifiers
I don't think I will place the thermistor and the current limiter circuitry on the F5. I want that bunch of small Hi-Q resistors and pairs of caps sounding at their bests. Adding more stuff get close to double the amount of components in the circuit.
Thanks, regards
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 2nd September 2010, 12:43 AM   #526
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
i put all grounds on the left center ground from pic.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 2nd September 2010, 08:54 AM   #527
you have shown 4pads on each PCB with red links.
Are any or all of these 4pads connected with traces on the underside?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd September 2010, 06:50 PM   #528
regiregi22's Avatar
Yes, Andrew, they are connected on the underside.
Teabag, I understand that you are joining both rail's grounds between the two gnd pads under and above the marked v+/v- output pads? Then, in which pads are you soldering the ground from the F5 board and the return from the speaker?
I'll do the same drawing in the underside, it should be clearer for you guys.
Sorry for a minor mistake. I wrongly drawed the connections from the diode bridges on the previous post. Not important for the matter.
Old 2nd September 2010, 07:13 PM   #529
Tea-Bag's Avatar
Regi,
Don't tie the two in the middle, just one on left between v+ and v-. Attach speaker ground to it, board grounds to it, and signal ground to board or here. Then attach CL60 to it, and other side to Chassis and IEC ground. Shouldn't hum.
Old 2nd September 2010, 07:23 PM   #530
regiregi22's Avatar
Originally Posted by Tea-Bag View Post
Regi,
When you actually say "it", what are you referring to?
Can I use some pads for the task of connecting spk return, signal ground, earthing...?
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
Copyright ©1999-2017 diyAudio
