| Group Buys Members group buys |
#431 |
Money has just been sent,
Nicolas |
#432 |
Boards showed up today Peter, beautiful, I'm glad I ordered another set. Thank you very much for the extra rectifier boards, they are very much appreciated!
I was going to build an F5 P2P, but these will add a very elegant touch. Have all my parts except for heatsinks and N-channel MOSFETS. This will be my first DIY amp - can't wait to hear this thing. Thanks again, Scott All hail Nelson Pass! |
#433 |
I've got my package last week, with an extra : a pair of rectifier bridge ! Thanks, those pcb are tiny and beautifull !
I've found all the parts on digikey, except 2SJ108/74 and 2SK170/370... |
#434 |
not politcally affiliated
Androuski, Member Blues has these for sale. I purchased from him last time.
Matched Toshiba FETs For Sale
SemiSouth R085/R100A JFET available now DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE |
#435 |
Thanks !
Can you confirm that 2SJ74/108 and 2SK170/370 are the only ones that need to be matched ? |
#436 |
Hi Androuski,
According to the designer himself, the JFETS need not be tightly matched, but do need to be in the same grade, preferably 'BL'. Recommended IDSS for the standard circuit is about 8mA. Many members on the board DO match these devices for optimum results. In other words: match if you can. Personally, I got lucky and even partly decided to build an F5 because I have had 20 each 2SJ74BL/2SK170BL from ampslab.com just laying around for almost 2 years - all measured and matched. It's sweet when you have the toughest parts to get in your parts bin! One last note: I have been scouring the threads for information on building an F5 with Toshiba 2SK1530/J201 outputs, one mod I have heard is using 6mA IDSS input fets rather than 8mA, any info is much appreciated, although any respondents should probably post on the F5 builders thread.... Scott |
#437 |
Thanks,
I'll see what I can get... |
#438 |
Hello,
Just a quick post to say thank you Peter, the rest of the boards arrived last Saturday. Very nice PS boards, perfect for an XL-280 as it happens. Will post as the adventure progresses....
#439 | |
I notice that the power supply PCB does not have provision for R9 and R10 as shown on the schematic found in Nelson Pass' service manual for the F5. If I remember correctly the value is 2.2k 3w. Are they not required, or added elsewhere? |
#440 |
Those resistors are not really necessary, if you want to ad them, they can be solder directly to the pads.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| F3 pcb group buy... | h_a | Group Buys | 253 | 23rd December 2008 01:40 PM |
| new to group | Lemalin22 | Introductions | 3 | 22nd June 2007 02:22 AM |
| What a group! | EvilGenius | Introductions | 6 | 25th May 2006 06:16 PM |
| ono group buy | xsnailx | Pass Labs | 106 | 14th March 2004 02:24 AM |
| Page generated in 0.21718 seconds (41.16% PHP - 58.84% MySQL) with 11 queries |
