Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 19th November 2009, 10:48 PM   #381
gervenja's Avatar
Default f5 or f4 board
hello Peter,
I am looking for a stereo board and a ps board.
What do they cost and what dos shipping to the netherlands cost.
regards
John
Old 19th November 2009, 11:19 PM   #382
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Shipping is included in a price of the boards.
F5 amp boards info: F5 pcb group buy...
PS pcb info: Universal Power Supply PCB
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th November 2009, 06:31 PM   #383
gervenja's Avatar
Hello Peter,
I received them last week, they are looking beautyful.
I am scoring the parts here and there and will post the end result.
best regards John
Old 15th December 2009, 01:32 PM   #384
phil101 is offline phil101  France
Hello Peter,
I have received the boards yesterday and as already said, they look beautiful.
Thank You
Philippe
Old 18th December 2009, 03:19 AM   #385
DECKY999's Avatar
Can anyone suggest a good source for parts (transistors that is). I could not find anything @ digikey or mouser.
The only true way is no way.
Old 19th December 2009, 09:47 PM   #386
You should be finding most everything there. That said, I took the easier route of using Tech-Diy parts pack. Jack participates on this board.
Russellc
Old 20th December 2009, 04:56 AM   #387
sangram is offline sangram  India
Note that the Tech-DIY parts kit needs a bit of work to mount properly on Peter's board. The resistors are all mounted vertically and the Ohmites mount to the back of the board. Can take a while to figure out how to mount these on a chassis this way...
Old 20th December 2009, 04:42 PM   #388
I just used the standard Tech DIY parts and stood the resistors up soldier style.
Russellc
Old 20th December 2009, 05:01 PM   #389
My parts kit was a bit different - I got sent a bunch of Ohmite resistors (which NP mistook in someone else's post as a cap).
This is my board:
Old 20th December 2009, 08:50 PM   #390
The board was designed to be used with Dale CMF50 resistors, available from DigiKey: http://dkc3.digikey.com/PDF/C091/P1890.pdf
For the large ones, use 3W Panasonic metal film, also avaialble from DigiKey: http://dkc3.digikey.com/PDF/B092/P1920.pdf
You may also consider 5W Mills and then use single 50R resistors replacing R5/R7 and R6/R8 parallel combos.
I would also suggest simplified amp circuit, without protection circuitry and thermsitors; it really works nice and according to others sounds better. Since such version uses even less parts, you may also consider Caddocks or Vishays: http://www.audiostereo.pl/zalaczniki/1272620_1.jpg
www.audiosector.com
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 01:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 02:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 06:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 02:24 AM
Page generated in 0.13561 seconds (82.01% PHP - 17.99% MySQL) with 11 queries
