F5 pcb group buy... F5 pcb group buy... - Page 6 - diyAudio
Group Buys Members group buys
F5 pcb group buy...
F5 pcb group buy...
Old 11th April 2009, 05:20 PM   #51
1MOR is offline 1MOR  United States
Peter, I sent PP for two F5 amp boards this AM. Thanks!
Old 16th April 2009, 05:37 AM   #52
alphalove is offline alphalove  Australia
Hello Peter,
Time for another buy! Think I'll do some balanced F5's.
I've just made a PayPal transfer for 4x F5 boards (8 channels).
Any problems, let me know.
Thanks again,
alex
Old 16th April 2009, 03:59 PM   #53
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
F5 pcb group buy... Send a message via AIM to Peter Daniel
Originally posted by alphalove
Hello Peter,
Thanks again,
alex
Great, the boards will shipt today. Thanks.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 16th April 2009, 11:24 PM   #54
sandbasser is offline sandbasser  United States
sandbasser's Avatar
Peter -
Do you have a BOM or parts recommendations for the Power Supply board shown in Posts 13 and 35 above??? It doesn't really look like the PS on the Pass website.
Sorry if this is a dumb noobie question; but, that's what I am.
Thanks,
- Ray
Old 17th April 2009, 01:29 AM   #55
The actual PS schematic for amp aplication as in attachment. To be honest, I never work with BOM, as it usually creates problems
When in doubt, follow the recommendations in F5 article. Digikey.com and mouser.com are good sources for parts in this case.
www.audiosector.com
Old 17th April 2009, 03:32 AM   #56
sandbasser's Avatar
Peter -
The PS I'm referring to (in Post 13 - and attached) shows film caps, small electrolytic and some kind of regulator. Do you have a schematic for that one?? Or, can you tell me where to find one???
Thanks,
- Ray
Old 17th April 2009, 04:37 AM   #57
lgreen is offline lgreen  United States
lgreen's Avatar
Default looks like a regulated PS
Looks like a regulated power supply.
Look at the LM317 data sheet or in this case the LT 1086 data sheet, page 14, top right hand side.
Neat little circuit, use them a lot; but I like to use the protection diodes you will see on the top of page 10 of the 317 data sheet. Not sure about using huge output caps either.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 17th April 2009, 05:38 AM   #58
Any 3-pin regulator will work with those boards and you just need to follow the appropriate datasheet applications.
www.audiosector.com
Old 17th April 2009, 07:38 AM   #59
schro20 is offline schro20  United States
schro20's Avatar
Default Re: looks like a regulated PS
But these only do as much as 1.5Amps. Nowhere near enough for an F5. What am I missing?
peter
Old 17th April 2009, 03:05 PM   #60
lgreen's Avatar
Default ah
ah...yes. The biggest ones I have seen are the LM138 and LM338 which will give you 5 amps max.
I do not believe that this board is intended to power the F5. You rarely see these used in power amps for the reasons you have noticed- lack of current capability... maybe only in a gainclone or something like that. There are other boards for the F5 power supply I believe.
F5 pcb group buy...Hide this!Advertise here!
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
Copyright ©1999-2017 diyAudio
