Group Buys Members group buys
F5 pcb group buy...
F5 pcb group buy...
Old 7th October 2010, 09:36 AM   #551
when do you hear this low level Hum?
Only when no source is connected, or only when the input is shorted, or only when the input is open circuit, or a combination of these?
regards Andrew T.
Old 7th October 2010, 01:41 PM   #552
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Andrew, I understood from him that shorting input to ground ceases the noise.
Try to hook up your source and then measure, maybe having the inputs without a ground reference (nothing hooked up, free-air) brings out noise.
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 7th October 2010, 07:31 PM   #553
shmulik is offline shmulik  Israel
F5 pcb group buy...
Default Hum
the hum occurs when the input is in free air. still there is a pull down resistor just for that. I'll try hooking a source (output of opamp) and see what comes.
any ideas regarding the second strange thing - the unequal heating of the bridges?
Old 8th October 2010, 09:00 AM   #554
that is a perfect way to reproduce music!
regards Andrew T.
Old 8th October 2010, 06:41 PM   #555
F5 pcb group buy...
Default catching air
some reviewers use the tarm "air between instruments" when refering to sonic qualities. isn't the best way to catch that air is with no instruments to begin with? the rest follows.
seriously speaking, this hum haunts me. several of my DIY attempts ended humming. I even had a GainClone the was perfectly mute, and after returning from a friend cought up humming I failed to remove. I must be doing something profoundly wrong, but I can not spot it.
Old 8th October 2010, 06:45 PM   #556
........seriously speaking, this hum haunts me. several of my DIY attempts ended humming. I even had a GainClone the was perfectly mute, and after returning from a friend cought up humming I failed to remove. I must be doing something profoundly wrong, but I can not spot it.
if you leave the input open circuit you have effectively added a high impedance aerial to the amplifier.
This is never the way you connect an amplifier to reproduce audio.
regards Andrew T.
Old 12th October 2010, 02:13 PM   #557
micio_mao is offline micio_mao  Italy
is it possible to have one stereo pair pcb?
Or they're finished?
Matteo
Old 6th November 2010, 02:16 PM   #558
jwor is offline jwor  United States
I would like to buy a pair of F5 boards if there are any for sale.
Old 9th November 2010, 12:56 PM   #559
Nikon1975 is offline Nikon1975  Austria
Me too, what's the difference with the boards in diyaudio store ?
D.
Old 10th November 2010, 12:09 AM   #560
Russellc is offline Russellc  United States
F5 pcb group buy...
D.
They are both F-5, just two different board layouts form two different sources.
The Daniels boards are more compact, the Cviller boards are a little larger.
There were originally some boards that later became available from Cviller as well, that had sufficient room for 4 out puts per channel, see his blog, and the group buy threads on both the Daniels and the Cviller boards for pics and building dicussion. They are both shorter than the gigantic F-5 thread, but it is certainly worth working through, take notes along the way.
Russellc
F5 pcb group buy...Hide this!Advertise here!
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
Copyright ©1999-2017 diyAudio
