Group Buys Members group buys
F5 pcb group buy...
F5 pcb group buy...
Old 15th September 2010, 11:19 AM   #541
R.I.P.
Originally Posted by regiregi22 View Post
Is it OK one slow-blow 1.25A fuse to protect one F5? I am going dual psu for it, but Nelson Pass psu schematic doesn't specify if it is for one channel or two. I live in 230v. I will use the thermistors in the transformer.
the normal fuse value for a motor or transformer is 3 * watts / voltage.
If you implement soft start properly then that factor of 3 can be reduced to near 1times.
Due to the way we specify our audio PSUs. I have found that the factor can even be less than 1. I commonly use 0.8 * VA / voltage without incurring nuisance blowing when the soft start is scaled to suit the transformer VA.
regards Andrew T.
Old 15th September 2010, 04:54 PM   #542
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
I don't know the total wattage, so without more concrete advices, I will go with twice the recommended. I am not sure if 1.25A fuse will suffice for two F5 channels.
regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 24th September 2010, 11:26 AM   #543
regiregi22's Avatar
I've been looking for inside the official F5 thread but I couldn't found info about matching the jfets idss (2sk170 and 2sj74). Is there anything expected to gain, performance wise?
I have seen some BOMs that recommends to match them. I think that I have to find one 2sk170 and one 2sj74 with the same idss.
AFAIK, offset is adjusted by trimming pots, so I suspect that there should be small advantages in that sense.
Can anyone apport something to this?
I have almost all my components collected to start building, only need the jfets
Thank you very much to all,
Old 25th September 2010, 04:10 AM   #544
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
It used to adjust the bias too.
Old 26th September 2010, 03:08 AM   #545
wdavis009 is offline wdavis009  United States
Peter,
What is the largest gauge wire that will fit the output holes on the amp board?
Old 4th October 2010, 01:20 PM   #546
kpaiss is offline kpaiss  Greece
Im really having hard time locating the panasonic 3w 0.47 resistors.
If anyone knows where can i find them.
Many Thanks !!!!
Old 4th October 2010, 05:20 PM   #547
cjkpkg is offline cjkpkg  United States
I get mine from Digikey. 3W panasonics
Old 5th October 2010, 07:14 AM   #548
oh...
I was sure that from digikey there was a limit order of 1500 pieces for this specific resistor.
My mistake.
Thank you !!!
Old 6th October 2010, 08:04 PM   #549
shmulik is offline shmulik  Israel
F5 pcb group buy...
Default some hum (?)
I experience some hum, or at least I think it is hum (some small multiple of 50Hz). one has to put his ear to speaker in order to hear the hum, but the target speaker is a 106DB sensitive one and the noise will be much more noticeable there. I measured the ripple of the rails while one channel is attached and properly biased (~0.59 Volts) on a scope and it is ~150mV peak to peak and similar on both rails. when the input is shorted to ground there is no noise at all. when the ground crocodile of the scope prob is attached, the nature of the noise changes.
Has anyone else experienced such noise?
one more odd thing - the rectifier bridge of the positive rail is getting hotter (by hand) than the negative one. I don't know what that hints.
Shmulik
Old 6th October 2010, 08:33 PM   #550
HaflerFreak is offline HaflerFreak  United States
HaflerFreak's Avatar
Default Wire gauge for PD F5 boards
At Wdavis009:
The absolute largest wire you can use for power/output with the original PD F5 boards is 16-gauge stranded if you twist it up nice and tight.
F5 pcb group buy...Hide this!Advertise here!
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
