Group Buys Members group buys
F5 pcb group buy...
F5 pcb group buy...
Old 2nd September 2010, 08:43 PM   #531
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 pcb group buy...
sorry, the ground connection between v+ and v- all in that place.
GB 2017 #2 CLOSED, Boards on Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 2nd September 2010, 09:50 PM   #532
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
And is there an elegant way of performing it? I am afraid the only solution to be a bunch of flying cables soldered to a copper jumper. That couldn't be an option with such a nice board
Can you post a picture of yours?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 2nd September 2010, 11:47 PM   #533
Tea-Bag's Avatar
F5 pcb group buy...
I will look for a pic, but that's the way I do it. Not sure where I picked it up.
I think someone from Poland had drawn it out for me that way.
Old 3rd September 2010, 01:59 AM   #534
sandbasser is offline sandbasser  United States
sandbasser's Avatar
Peter shows lots of pictures in the Universal Power Supply thread in the Vendor Forums (under Audio Sector) that should explain everything. Postings #4 and #32 in particular may be of interest to Regiregi22's query.
- Ray
Old 3rd September 2010, 04:56 PM   #535
regiregi22's Avatar
Old 13th September 2010, 07:11 PM   #536
regiregi22's Avatar
I haven't yet found an elegant way to hook up grounds. Its a pity doing that way having so many holes on the PSU board.
On another matter, I've seen that the recommended transformers are around 250VA or 300VA ratings. I know these are recommended values for long term stability, lower heat, constant current class A consumption, bla bla bla...
But in practice, if my maths are right, one F5 channel would consume 1.3A times 36v (2x18vac voltage swing), which is around 47VA.
Now my question is not wether is it recommended a 47VA trafo (I know it isn't), but if one F5 channel just consumes 47VA.
Does one F5 channel needs just 47VA?
Old 13th September 2010, 07:36 PM   #537
47VA, no.
Because the transformer does not see/feel/react to/heat up the same as it would do passing 1.3Aac through a resistor.
regards Andrew T.
Old 13th September 2010, 10:50 PM   #538
regiregi22's Avatar
thanks
It has something to be with the inductance, or because of the lower resistance than a transformer coil use to have comparing it with a resistor?
Regi
Old 15th September 2010, 11:58 AM   #539
regiregi22's Avatar
Is it OK one slow-blow 1.25A fuse to protect one F5? I am going dual psu for it, but Nelson Pass psu schematic doesn't specify if it is for one channel or two. I live in 230v. I will use the thermistors in the transformer.
Old 15th September 2010, 12:15 PM   #540
it's mainly due to the heating effect in the primary and the secondary depending on I^2 rather than simply I.
The current pulses that charge up a capacitor input filter demand that the transformer be de-rated according to the manufacturer's data.
regards Andrew T.
F5 pcb group buy...Hide this!Advertise here!
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 01:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 02:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 06:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 02:24 AM
Copyright ©1999-2017 diyAudio
