Group Buys Members group buys
F5 pcb group buy...
F5 pcb group buy...
Old 29th July 2010, 04:20 PM   #511
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
F5 pcb group buy... Send a message via AIM to Peter Daniel
I did some measurements how bias stabilizes in my amps (without thermistors): http://www.diyaudio.com/forums/group...ml#post1935126
To order kits contact me through forum mail.
Old 29th July 2010, 04:23 PM   #512
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F5 pcb group buy...
I think the thermistors help National Semi's keep a little more stable with thermistors, but importantly allow it to bias up quickly.
With no thermistors, and IRF's or Toshibas, I see rock solid offset (no drifting). It does take longer to warm up, but I say doesn't make much difference in sound after 30 minutes.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 29th July 2010, 04:32 PM   #513
sangram is offline sangram  India
I find that there is a big variance between summer and winter bias and offset levels without thermistors. Basically, once you set the bias without thermistors, the amp likes to remain at the same ambient conditions that you had when you set the bias.
Else the bias goes up when the ambient temps increase, and down in winter or monsoon seasons. Thermistors do keep this more stable and reduce the amount of fiddling one has to do to keep everything nice and happy, but what good is an amp if you don't have to open up the hood once in a while anyway? And in my case, it's pretty much unusable with the 35 degree + room temperatures of a tropical summer, so for me it's a winter amp only.
However, omitting the thermistors results in much more stable bias and offset over a short-term period - personally speaking. I checked over a period of about ten days and the bias did not move at all from where I set it, and the offset was <2mV on each channel. Picture changes when the seasons change though, but I prefer that to a shifting bias point that is almost impossible to pin down with the default configuration. I end up having to keep the amp on for an hour or so to get bias to the exact point I want it at, which is fine as it is playing music at the time
Old 30th July 2010, 01:30 PM   #514
Russellc is offline Russellc  United States
F5 pcb group buy...
Peter, can I still order a set of your F-5 boards?
russellc
Old 30th July 2010, 08:17 PM   #515
F5 pcb group buy...
Peter, in post 300 you said once it reached .659 "It was steady as a rock."
Is it OK to leave at this higher than .59 bias point? Or did you scale it back down?
thanks,
Russellc
Old 4th August 2010, 09:37 PM   #516
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
PSU and F5 boards perfectly received and packed.
Thank you very much, Peter
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 5th August 2010, 01:36 PM   #517
F5 pcb group buy...
Peter, are you on vacation, or is this buy now closed?
Russellc
Old 6th August 2010, 06:24 AM   #518
lloop9 is offline lloop9
I'm interested in a set as well...
Old 12th August 2010, 07:34 PM   #519
angolocottura is offline angolocottura  Italy
Can I still order a set of your PSU and F5 boards?
Old 13th August 2010, 01:36 PM   #520
F5 pcb group buy...
I think I got his last set of F-5 boards. I dont know if there are plans to have more made. Peter told me he had the PS boards still. Will there be more Peter?
Russellc
F5 pcb group buy...Hide this!Advertise here!
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
