Group Buys Members group buys
F5 pcb group buy...
F5 pcb group buy...
Old 21st May 2009, 03:42 PM   #131
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
F5 pcb group buy... Send a message via AIM to Peter Daniel
Originally posted by ccschua
Saw your photo R5 to R8 using 50R but the BOM on may 24 is using 100R.
I use a single 50R/5W. The BOM suggests 2 x 100R/3W in parallel, which is basically the same.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st May 2009, 10:16 PM   #132
audiojoy is offline audiojoy  United Kingdom
Dear Peter i have to agree with speakrsfun, for us shall we say less use to electronics,the power supply boards does make it quicker and easier without having to think about orientating the diodes correctly and get the negative and positive voltage outputs correct as well. Not difficult I agree, but each time i come to do it i have to keep reconfiguring the orientation of the diodes. Remember some of us may do something like this only a couple of times each year, it does not come naturally. It is also neater, smarter looking and hence psychologically more satisfying as well.
Old 22nd May 2009, 05:45 PM   #133
ccschua is offline ccschua  Malaysia
Hi Peter,
1. Can I use 0.5W instead of 0.6W?
2. Power supply R1 to R8, instead of 0.47R, if use 0.1R total how many required ?
3. How about R11, R12 can use 0.1R ?
Your urgent reply is appreciated.
Old 22nd May 2009, 06:00 PM   #134
1. You can even use 0.25W resistors.
2. That's what I actually do, I use single 0.1R resistor with 10W power rating (or similar)
3. No you can't, those need to be exact values.
www.audiosector.com
Old 22nd May 2009, 06:06 PM   #135
1. will do.
2. Total 0.1R 10W is 2 units and these 2 units replace R1 to R8 right.
ps. can email me the nelson ps circuit diagram.
1. Do u think 2 units of Mundorf M-lytics 47,000uF works supreme for F5 or Jensen? or better 4 units of 47,000 (which means no regulator is required right)
Old 22nd May 2009, 06:56 PM   #136
No regulator is required no matter what caps you use.
Never tried Mundorf's so can comment on their performance.
www.audiosector.com
Old 22nd May 2009, 11:10 PM   #137
wagrubbs is offline wagrubbs  United States
Default To Peter Daniel Re: Pass Zen V9 boards
I am new to this forum and am not allowed to e-mail yet. I built several Pass Zen's when they first came out 12 years ago to power K-horns. They were lost in a fire and I would like to build them again, with updates of course.
How do I go about joining the 'group buy' process to obtain 3 PC Boards?
Thanks in advance!
Andy Grubbs
Chapel Hill, NC
Old 23rd May 2009, 12:14 AM   #138
Just follow the instructions in a first post: http://www.diyaudio.com/forums/showt...5&pagenumber=1
www.audiosector.com
Old 25th May 2009, 03:42 PM   #139
Default Re: To Peter Daniel Re: Pass Zen V9 boards
Zv9/ F3 boards are currently out of stock. There was a recent wiki page to check the interest, but only few entries came up. I might run another batch somtime in a future, but it won't happen soon. You may post wanted ad in Trading Post section, as I'm pretty sure not everybody who purchased the boards went into building the amps.
www.audiosector.com
Old 26th May 2009, 07:48 PM   #140
Beftus is offline Beftus  Netherlands
Beftus's Avatar
Got my boards today. I didn't expect the boards to be so small. I initially thought I had received a single amplifier channel...
The boards are great, thanks Peter. BTW, not bad, from Canada to the Netherlands in only 7 days!
F5 pcb group buy...Hide this!Advertise here!
F3 pcb group buy... h_a Group Buys 253 23rd December 2008 12:40 PM
new to group Lemalin22 Introductions 3 22nd June 2007 01:22 AM
What a group! EvilGenius Introductions 6 25th May 2006 05:16 PM
ono group buy xsnailx Pass Labs 106 14th March 2004 01:24 AM
Copyright ©1999-2017 diyAudio
