Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 6th June 2009, 03:31 AM   #571
shmulik is offline shmulik  Israel
Default more measurements
thank you for the measures. I need one more though: what is the size of the drv boards (total size and between holes).
I also intend to place all parts in a single box. This makes a very crowded arrangement. As regulators I intend to use TeddyRegs from the pink fish media DIY forum. I also intend to regulate the power amp's rails by using PowerReg of the same source. I may have to replace the pass transistors to something that can hold higher current as the suggested D44h11, when taking into account the losses for heat in addition to the load current, is marginal.
Shmulik
Old 6th June 2009, 05:08 AM   #572
Juluska,
in the original BOM at Alex's site the pitch is 9.5 mm. can youverify your measure? both sizes are available in Farnell's inventory.
thanks,
shmulik
Old 6th June 2009, 06:39 AM   #573
juluska is offline juluska  Ukraine
Default Re: more measurements
[QUOTE]Originally posted by shmulik
[B]thank you for the measures. I need one more though: what is the size of the drv boards (total size and between holes).
Here you har the drv scan in high def:
http://ignatiusprojects.blogspot.com/
Old 6th June 2009, 06:45 AM   #574
Juluska,
thanks,
shmulik
yes, the pitch is 9,5mm.
Old 6th June 2009, 08:56 AM   #575
That is what I call good service! Thanks.
now if you could roll that PCB 90 degrees and show the other dimension that would be perfect, unless it is a square (seems a bit higher than wide on the photo).
I wish the PCBs could be sent over email or downloaded from the forum just like pictures...
Old 6th June 2009, 01:17 PM   #576
42x43,50mm
Here you har the drv new scan in high def:
Old 6th June 2009, 07:18 PM   #577
Juluska,
Thank you again. However, I could not escape noticing two facts:
1) you were using the same ruler for the two measurements (and combining photos)
2) this ruler is only true at 20 degrees Celsius.
were you meticulously keeping the temperature stable between photos?!
Sorry about that. it is stronger than me and I could not resist the temptation. must be the Mediterranean summer
Shmulik
Old 6th June 2009, 07:30 PM   #578
Juluska,
Shmulik
Stell dilatation coeficient is 12x10-6, I'm in Tarragona at 23ºC, so the measurement error is about 0,042mx12x10-6x3ºc= 1,26x10-6m.
Old 6th June 2009, 08:41 PM   #579
HaLo6 is offline HaLo6  United States
HaLo6's Avatar
juluska or anyone,
Question, I bought the kit from rhysh as well, but the SMD caps aren't labeled like resistors are, how do you tell them apart?
Old 6th June 2009, 09:29 PM   #580
Originally posted by HaLo6
juluska or anyone,
I have the same problem, there no mark or numeration.
Page generated in 0.11639 seconds (77.84% PHP - 22.16% MySQL) with 11 queries
