I completed mine, and I am getting a little high frequency hiss and noise, is that what you are talking about?
No. I connected a signal generator on the input and oscilloscope on the output (in parallel to 8 Ohms power resistor) and played sine and square waves. With the sine wave I measure the amplitude while raising the frequency and watch its magnitude. I want the amplitude in a fixed value as a function of frequency for high enough frequency (well above 20KHz). with the square wave I just examine the form of the wave. in my case it rings - has decaying oscillations right after the fast rising (or falling) edge. if I increase the feedback capacitor this ringing is weakens but the frequency response suffers.
both effects influence the sound quality of the amplifier. you get either boomy bass or lack of spice and attack.
Alex reports excellent measurements. therefore I suspect I did something wrong, either while building the modules or in their installation. I'm working now on insulating the problem but with no results yet. if others have measurements it may hint me where is the fault in mine.
Still measuring/sounding badly?
Your post made me curious as I`m picking up a set of boards for the BPA300 tomorrow.
Did you make your own boards/where did you buy them?
Did you follow the original BOM?
Boards for BPA300
Hi
I have a set of boards from the P-A Sjostrom - 4 x PA150 boards plus 2 x DRV Balanced Driver boards plus 2 x DRV ICs plus all SMD parts for the PA150 boards. The DRV boards are the ones which had X4/X2/X3 mis-labled.
I am unlikely to ever build the amps - so open to offers.
Alan
Anybody knows some place to get some of these boards or other similar ones? I have seen some websites, but they currently don't carry them.
I can take as a good suggestion to propose other board with a variation in the amount of devices, etc.
Thanks,
Hi
Alan
I have 16 boards and all of the components, but I was planning on going the audio transformer route so I did not buy the inverter or solen input caps. If anyone is interested respond here
http://www.diyaudio.com/forums/swap-meet/180484-lm3886s-components-pcbs-bpa300.html
Hi
Alan
I sent you a PM. Send me one with an orientative price. I have already ordered the DRV134 boards from P-A, so I am not really interested in them. Can I assume that the smd resistors are 0.1%?
Neither of them are a problem if you really want to sell the whole as a kit.
Regi
Hi, I have a question regarding first power up. Is there a preferable position of the dc tunning trimmers, like 0 ohms, 50kohms or the middle position?
Regi
I don't think it matters, at least in my case.
For example,in the F5 amplifier,it is advisable to start with the trimmers at 0 ohms and starting turning them up half a turn each one,until you get to the proper bias and dc offset.
Turning just one pot to the end without turning the other leads you to burn the amplifier
Hello All
Looking for 4 bpa boards also smd parts. Im in the uk , can paypal straight away.
Dave
http://www.diyaudio.com/forums/swap-meet/181953-disposing-unused-mjl21193-94-many-more.html
- Group Buys
- BPA300 Round 2
