| Group Buys Members group buys |
#41 |
I have got a deal for the price break we require, just need 20 more pcb's to be taken.
#42 |
Just to let everyone know, i will do ALL your SMD soldering for $5 (to cover the cost of solder and time), plus the price of the resistors.
#43 |
Hello Everybody,
Has anybody tried to use a BPA300 design for a PA system? The speakers would be 8 ohms but could be changed to 4 ohms since I haven't built them yet. I want an amp that has some power but enough headroom to reduce clipping. if there is a problem with the amp, being homemade they would be easier for me to fix (I would already have repair parts). Live PA work doesn't require high end sound quality but the equipment does need to be robust. Will this fit the bill? I'm thinking some sort of soft start, speaker protection, a stepped attenuator front end with hi Z and balanced inputs would be all that is needed, any comments? Oh ya, I know it would be cheaper to buy some Crown DC300's but this will be a lot more fun not to mention the bragging rights. Thanks, Mark
I have proof that God exists; he divinely inspired the invention of spell check just for me. |
#44 |
Home audio and PA should never be crossed, unless for personal use due to health and safety risks. You dont want to be held responsible for a venue burning down becuase your amps dont have the required safety features. This has been discussed mant times on the forum but i will leave it up to you to decide.
In theroy, the amplifier will be fine for light PA use. Use overkill heatsinks and an oversized power supply. |
#45 | ||
I like to join this GB for 4 boards. Wiki updated. Quote:
if I need your help to solder them on board. Cheers TS |
#46 |
Hi, i will update the price for the resistors when i have looked into it a bit more. I am thinking about supplying kits, with the option of pre-soldered SMD resistors.
#47 |
Can i just ask how many people would be intrested in a kit? Price would be around $125 per monoblock, to populate a pair of PCB's.
#48 |
when you say kits, do you mean parts only? or parts & pcb's?
I would be definitely interested in parts only for 4 boards regards Evan
"I don't remember fighting Godzilla, but that's probably what I would've done" |
#49 | |
Parts only, as this is a group buy anyway people will be supplied with boards to use with the kits Not a problem as you allready have yours. |
#50 |
great stuff, count me in for parts for 4 boards then
i was looking at farnell the other day and noticed that the susumu 0.1% resistors are quite good value. however that's true for small quantities, you might be able to strike a good deal on welwyn or vishay resistors depending on demand quantities best regards Evan
| Page generated in 0.11444 seconds (77.99% PHP - 22.01% MySQL) with 11 queries |
