| Group Buys Members group buys |
#31 |
Virtually every solid state amplifier works better into a higher impedance load.
If you go for a 50W into 8r0 design and parallel them and bridge them you'll get 100W into 16. That's 56Vpk and 3.5Vpk into a resistive load. A parallel pair will deliver 5Apk from each chipamp. A parallel triple will deliver 3.3Apk from each chipamp. The worst case transient current into a 16ohm load is around 10Apk. Either version will work well.
regards Andrew T. |
#32 | |
Thank you, Mike DuFresne |
#33 |
50 left.
#34 |
6 cards for me.
#35 | |
wiki confirmed. also you got RE: mail |
#36 |
Posted in the other thread by accident... oops.
Bump me up to 16 boards. (four stereo sets). I have updated wiki. m |
#37 |
Up to now I have been making the assumption that, of the two boards per channel, one is the BPA150, and the other is the power supply.
Is that assumption correct? I just now have been looking through all of the BPA300 threads, and I don't think any of them have posted a photo of the PS board. m |
#38 |
There are two boards per channel, both amplifier boards (identical).
. For a monoblock you need 2 boards. Stereo amp 4 boards.
#39 |
Is there any possibility to supply the pcbs with the smd components soldered? What about price?
Thanks |
#40 |
This is entirely possible. How many pcbs would you require? I will charge a flat rate of $5 for soldering resistors in total, excluding resistor cost.
| Page generated in 0.11301 seconds (72.23% PHP - 27.77% MySQL) with 11 queries |
