| Group Buys Members group buys |
#1001 |
Electrons are yellow and more is better!
Rhys, you have been online today and most likely read the thread you are involved in and I'm pretty sure you have subscriptions of this thread. Send me an email, SMS or call me. We must have info about your actions.
/Per-Anders (my first name) or P-A as my friends call me |
#1002 |
The price is approx. one dollar each and the shipping cost 26 SEK world wide.
#1003 |
SMD kit per pcb will be 120 SEK plus 26 SEK shipping for maybe 10 kits. The parts are pretty expensive in small quantities but if you want some help, I can help you. I'm going to order parts from Farnell so can order those too. I will order this weekend so hurry up if you want these parts.
#1004 | |
#1005 |
I though of allowing adding balanced input to the amplifier, merely because my line stage has balanced output only. I thought of 2 options:
1) using the INA137 counterpart of the DRV134. switching between single ended and balanced via a relay and switch on the back panel. the output of the 137 is the input of the 134 2) using a differential line driver (what chip? I have no SMD PCB creating ability so DIP is preferred unless someone will produce such board for me). do I need a pulldown resistor at the input of each PA150 until switch is made (see below)? option 1 is modular and easier to implement with my humble means on a strip board but it has a longer audio path compared to the second option which requires a switching of 2 lines compared to only one in option 1. assuming I will switch only with power off, I still need to consider how to handle the time it takes to switch in both options, so no input is left on air. please comment and share your ideas. Last edited by shmulik; 16th September 2009 at 07:56 AM. Reason: clarify |
#1006 | |
Since Rhys didn't deliver the SMD resistors (for which I paid him), I would like to join in your collect order. Please count me in for 2 kits SMD parts. Thanks for all the great work, Per Anders! Lucas |
#1007 | |
#1008 |
P-A,
sent you mail with sketches . has it went through your electronic fortifications |
#1009 |
I have got it. Just wondering, what is your need for this pcb? Do you want an amp with dual inputs?
#1010 |
my current linestage has balanced output only (actually it is a modified Behringer dcx2496). one can use this balanced output as it is with a single ended power amps (like I do today), but wire to single phase and then expand to 2 phases (by using the drv) seems awkwards to me. it is more natural to just buffer the differential input with something like the opa1632. however, balanced-input-only power amp is a kind of intentional disability if you ever want to take it to other systems.
taking the above into account, I plan to place both RCA and XLR sockets on the back of the amp and switch between the two per need. I don't mean to do the switching online, though, e.g. for comparison purposes. |
| Page generated in 0.11622 seconds (83.02% PHP - 16.98% MySQL) with 11 queries |
