| Group Buys Members group buys |
#981 | |
jim
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP |
#982 |
Thanks Jim...
When I look at the Nelson Pass owners manual, the Power supply is connected to the chassis ground via a thermistor. Yet from what I can determine Christian's wiring diagram does not connect the PS to chassis gnd. I have also seen diagrams with "star ground" configurations where even the -ve speaker terminal is connected to the star ground as well as the PS and input signal ground. Will all of the above work in the same way are these other methods for special applications?? |
#983 | |
#984 | |
Ummmm, According to what I read the Varistor is there to prevent (slow down) blowing a fuse when the torrid transformer starts up. In which case there 2 of them. or are you referring to the thermistor on the Mosfet? Which is used for stability (thermally) Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 |
#985 |
Nope, I was wrong.......yeah, again. I get them mixed up all the time.
![]() They are Thermistors, type CL60. As in the schematic ripped off straight from Pass Labs website. Ron
#986 |
I guess my real question is , does the power supply need to be connected to chassis ground??
It appears that some do and others don't make this connection... |
#987 | |
The first pic is the thermisters the second pic shows the 2 ground wires from power supply pcb the third completed I figured that once it worked I would go back and shorten and generally clean up the wiring, however it sounds so good I have just been listening. ![]() I would think it's right, because the amp is completely silent with volume at max and no source playing. I connected the power supply board to ground.
#988 | |
As far as the 2.2k 3Watt resistors on the power supply, they are optional, used to drain the caps on power down for safety. If you have speakers connected they are not necessary and perhaps sounds better without them. The R3&R4 2.2k resistors do not need to be 3Watt. |
#989 |
space charged
Is that a hunk of u-channel alum. to clamp down the outputs?
That would give some extra finned cooling. How did you bolt it? Through the mosfet holes or not.
#990 | |
here is a pic of the bolts, they are 10-32, and are on both sides of the mosfet. jim
| Page generated in 0.13887 seconds (83.17% PHP - 16.83% MySQL) with 10 queries |
