Go Back   Home > Forums > Commercial Sector > Group Buys
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Group Buys Members group buys
Thread Tools
Old 20th November 2009, 03:01 PM   #971
CJC is offline CJC
Hello Christian,
Received the boards today They look great!
Thanks!
CJC
Old 20th November 2009, 04:20 PM   #972
rtate is offline rtate
Default PS Board question
I'm putting my PS board together and have a couple of questions...
The BOM that I am using has R9 and R10 as the 2.2K 3watt resistors used for
discharging the caps on power down.
Looking at a schematic I think that these resistors shoud be in the R1 and R4
locations.
R2,3,5,6,7,8,9 and 10 are the .47 ohm resistors, is this correct??
Also what are the T13,14,15,16 and T7, T18 conections for?
Thanks....
Old 20th November 2009, 05:41 PM   #973
T18 is a typo, it should have read T10...
Sorry for the confusion...
Old 20th November 2009, 06:33 PM   #974
Hi, Any more F5 boards available?
Thanks, Daniel
Old 22nd November 2009, 10:33 PM   #975
Hi, any more F5 boards available?
/late to the party ... as always ...
Old 23rd November 2009, 03:15 PM   #976
Renron is offline Renron
Renron's Avatar
locations.
Thanks....
They are used for extra power taps, as Christian has stated before he designed these boards to be used with / as other designs too. Good thinking!
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
Old 23rd November 2009, 03:23 PM   #977
Thanks Ron,
Do the 2.2k bleed resistors go in the R1 and R4 locations??
Old 23rd November 2009, 03:35 PM   #978
Renron's Avatar
rtate,
You are correct. To answer any other questions, or just FYI. Christian has a very good PDF on the build of the PS & F5 boards.
http://viller.eu/audio/2009jan_gbf5/gbf5_guide.pdf
Ron
Old 23rd November 2009, 03:58 PM   #979
Thanks Ron, I do have a copy of that guide and should have checked there first.
Sometimes when these threads get long, some mis information(although good intentioned) slips in and I had made a copy of another BOM that had the bleed resistors in the wrong spot and I saw some photos over ar AK that also had the resistors in the wrong location....
Thanks again.
Old 23rd November 2009, 05:36 PM   #980
Renron's Avatar
My PS bleeds down to 0Volts in about 20 seconds.
Ron
Thread Tools
Page generated in 0.07863402 seconds (68.33% PHP - 31.67% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
