| Group Buys Members group buys |
#711 | |
And I got the payment and confirm mail - this gb site seems to be working smoothly.
#712 | |
#713 |
Hi Christian,
From your Jan. GB: I've been distracted lately with putting together/equipping a varily decent build/test bench: Just current with thread. Curious; the new PCB-3/13/09, Is only change to Q5 silk? Also, new Rect.B PCB---2 diode bridges, etc. vs PCB. Is improvement because of 'better' ultra fast recovery of To-247 devices like MUR3020W? Or is mainly just to simplify/organize PS input? On brd heatsink option a +plus if needed; yes but I'm using big Conrads with plenty of surplus 'sink' for To-247 RBs . If no real advantage, RectB PCB seems more costly? Just curious, cause cuz last GB you only had 1/2 of PSU brds I needed so I got a couple of Peter's PSBs with snap off RB chips. Just considering my PS options. Thanks Charles
I'm kinda curious about that myself........ |
#714 | |
2. Well lots of people have asked for these, and they make it easy to use ultra fast recovery diodes and supply more current for bigger amps. In fact I consider them of general purpose nature - and not directly related to the F5, although it seems like an upgrade well worth it. |
#716 |
Order just sent for set of F5 PS boards.
#717 |
Do high speed rectifiers make this amp sound better? Doesn't Nelson use ordinary bridge rectifiers?
#718 |
Some informations from Nelson PASS about Power Supplies :
http://passlabs.com/articles.htm Download the PDF and read the section about Recifiers. "Yeah, sure, rectifiers are important, after all, the AC has to get converted to DC, but I don't like the fast recovery types that some audiophiles have raved about. Fast recovery means that they withstand many amps and volts in a tenth of a few nano-seconds, something we don't see very often on the old 60 Hz AC line. They are essential element in switching power supplies, but for regular "linear" power supplies, I much prefer SLOW diodes, and we create them by placing small capacitor circuits across the diodes, which greatly reduces radiated noise." Just wondering about the caps type and values...
#719 | |
Papa has changed his mind since that article, I have read it several times in the pass labs forum, but my search only gave this reference: http://www.diyaudio.com/forums/showt...830#post321830 This may also be an inspiration: http://www.diyaudio.com/forums/showt...ght=#post17199 |
