Gb: F5 Pcb - Page 40 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 16th January 2009, 02:18 PM   #391
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally posted by noelectrix
hope i can get immediate help here
my source resistors do measure 0,6 ohms instead of 0,47 ohms. The rings do lable them as 0,47 !
so can i use them and set the voltage across them just a bit higher to get the right bias? Or do I have to search ore suitable ones?
tnx
stefan
(if question s…ks here, gimme a hint)
< 5 ohm resistors don't measure well with most DMM.
Most of mine will measure .6 ot .7ohm.
I would assume they are good and stick with .6v.
Old 16th January 2009, 02:24 PM   #392
Originally posted by cviller
You're right except for the multiplication... should be 780mV!
yes that what i meant. Dont try this at home
It is stuffed, completet exept the trannies led and R35.
Idon´t need R35 and the led to run it, right?
I have to go to an exhibition in 2 hours, and so I won´t finish it today. It was a pleasure to solder that thing.
Did I mention it anywhere… thanks a lot
stefan
Old 16th January 2009, 02:27 PM   #393
cviller is offline cviller  Canada
cviller's Avatar
I think you're right.
Noelectrix, if you want to be absolutely sure, you could measure the rail current with your meter (if i has that option), and then you can see what the corresponding voltage is. You might discover that everything is all peachy!
EDIT: The led is completely optional, but if you have a LED and a >20k resistor, then just put it in for testing.
Old 16th January 2009, 03:14 PM   #394
CfM is offline CfM  Germany
My PCBs also arrived today.
Christian, thanks a lot.
Greetings,
Chris:
Old 16th January 2009, 05:36 PM   #395
zei is offline zei  Sweden
Got my PCB,s today.
They look fantastic!.
Tackar och bockar.
/JZ
Tala är tiga, silver är guld
Old 16th January 2009, 05:53 PM   #396
steenoe is offline steenoe  Denmark
steenoe's Avatar
tnx
stefan
How did you measure that? A cheap DMM can't measure so low a value precisely I bet that they are in fact 0.47r.
You have to send some voltage through them, and measure the voltage drop across them, if you want them to be precise. Ohm's law rule!. A DMM is much better at measuring voltage
Old 16th January 2009, 05:57 PM   #397
helfred is offline helfred  Denmark
My PCBs also arrived yesterday.
helfred
Old 17th January 2009, 08:57 AM   #398
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
PCB'S Arrived this morning, Thanks!
Old 17th January 2009, 11:43 AM   #399
XELB is offline XELB  Portugal
Received mine yesterday.
They look great, thanks!
If you want power you must add control
Old 17th January 2009, 08:51 PM   #400
both channels working
veery nice trebles…
boards are very nice to adjust with mounted the trannies "under" and the board on top with pots nice to reach.
have to listen now
stefan
Copyright ©1999-2017 diyAudio
