Group Buys Members group buys
Gb: F5 Pcb
Gb: F5 Pcb
Old 3rd January 2013, 12:06 AM   #1421
Renron is offline Renron  United States
Renron's Avatar
Christian,
Just wanted you to know that my F5 (your PS & Amp boards) is used everyday and sounds fantastic. Missed you this year at B.A. , but I'm sure your glad to be back home.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 3rd January 2013, 01:02 PM   #1422
cviller is offline cviller  Canada
cviller's Avatar
Originally Posted by intense-tavda View Post
Hi Cviller!
I put the boards together, the F5c version from you, and got to much voltage on the output, 0,1 volt, and the powertransistors are getting very stinky hot. For R1 and R2 I got 10 watt 10 ohm resistors. Is it possible that the wattage from those transistors is to high? And are there maybe connecting points that I( missed, because I am using this board only for F5 purpose, and not for the Turbo version. Thanks for the answer. I think I got Q5 an Q6 right now an also P1 and P2.
Watt tolerance will not be the issue - more likely, you have made a mistake somewhere or have not taken it sufficiently slowly with P1&P2 adjustments. If you want help, you could post some pictures and better descriptions of what you have tried and what voltages you have measured where.
Old 3rd January 2013, 01:05 PM   #1423
cviller's Avatar
Hi Renron, thanks for the update and I would also have liked to be at the BA. I hope I will soon be able to come again - hopefully before it turns into a super-organised event!
Old 3rd January 2013, 06:21 PM   #1424
Renron's Avatar
:nown ow:
Gb: F5 PcbHide this!Advertise here!
