Group Buys Members group buys
Gb: F5 Pcb
Gb: F5 Pcb
Old 7th July 2010, 03:20 AM   #1291
Renron is offline Renron  United States
Renron's Avatar
Originally Posted by Tripmaster View Post
Hi
Are they required if I am supplying the LED with DC rather than AC?
A/C to LED's? Maybe once, but not twice?
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 7th July 2010, 07:52 AM   #1292
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Ron
Hi Ron
Possibly the wrong choice of words in no particular order
In the past I have created a low voltage AC supply by adding a separate winding around a toroidal transformer. I guess I should have said the diode wired in parallel with the LED creates a simple half wave rectifier!
Old 7th July 2010, 09:44 AM   #1293
R.I.P.
I know what you are asking/describing.
regards Andrew T.
Old 7th July 2010, 03:34 PM   #1294
Renron's Avatar
Hi Ron
Yes Andrew,
I too knew that a diode could be used in that configuration. However, not all of us are as knowledgeable as you (I'm not anywhere close) and I'm sure someone who just happened to read the above A/C reference would try it on a LED. (No Sarcasm intended)
We need to think of everyone who might read our posts and their experience level. Which is why we repeat ourselves on the Grounding / Neutral differences.
It was not all that long ago I was a total newbie and didn't know LEDs were D/C only. I've lost the total part but I'm still a newbie.
Thanks for the pic and explanation Tripmaster. How do you know how many windings to put on the torrid? Ratio based? Trial and Error?
Ron
Old 7th July 2010, 05:02 PM   #1295
Tripmaster's Avatar
Yes Andrew,
Ron
Hi Ron
It was trial and error. The number of turns required for the desired voltage will depend on the size of the transformer. I think I'll just tap off of the PCBs , but as the transformer is at the front of the case it may look neater in terms of cable length.
Old 8th July 2010, 06:17 PM   #1296
cviller is offline cviller  Canada
cviller's Avatar
I have gotten a few mails about availability of my boards and I'll answer here to everyone. I am currently in the process of moving back to Denmark and most of my stuff including boards have been shipped by sea, so I'll only get them back in the middle of August. At that time I'll be able to sell the remaining boards.
Old 8th July 2010, 09:22 PM   #1297
Renron's Avatar
Christian,
I for one, will miss you. ;(
Ron
Old 3rd August 2010, 12:04 PM   #1298
Russellc is offline Russellc  United States
Gb: F5 Pcb
If available, I'd like a set of the circuit boards, diode boards and P/S board for one stereo amp. I can wait until mid August, no problem. Will they be available then or do I need to pay pal now to reserve?
Thanks, and have a good move,
Russellc
Old 3rd August 2010, 06:58 PM   #1299
cviller's Avatar
I'll open the order site when I'm ready to sell the boards. Hopefully, I'll get them late this week, but it might take some time to find suitable envelopes if the ones I have here in Denmark are too small.
I'll post on this thread when I'm ready to receive orders.
Old 3rd August 2010, 07:18 PM   #1300
Gb: F5 Pcb
Thank you, I'm needing a set!
Russellc
Gb: F5 PcbHide this!Advertise here!
