| Group Buys Members group buys |
#1211 |
Glad to see this thread still kicking!!
My F5 is working great but I have a slight hum in both speakers that I would like to get rid of. The speakers are very efficient at about 95db and with no music playing I can hear a hum from about 3 ft. I was wondering if anyone is using a "star ground" and if so how is it connected?? I would like to try this to see if it will help. |
#1212 |
rtate, could you please take a picture where we can see the wiring or draw a (detailed) diagram of your wiring? Someone might be able to help you then. My F5's are very quiet, but I have a chip amp that picks up mexican radio!!!
Mine is wired like this: http://viller.eu/audio/2009jan_gbf5/...74_wiring1.jpg |
#1213 |
Hum is often caused by chassis grounding and ground loops between components, so if you could draw that as well it would be great. You can use a thermistor to connect chassis to gnd and thus limit some types of hum.
#1214 |
Thanks Christian, I have wired my F5 as per your picture above.
At this point I do not have anything connected to a "chassis ground" only the safety ground is connected which I have tried both on and off. I have been moving my gear around latley and will take some photos as soon as I can.... |
#1216 |
If by insulated you mean insulated from the chassis then yes.
I tested with a meter to insure no grounds or shorts. |
#1217 |
I have not read this article, but it may offer you some advice/clues while we are waiting for the pictures:
Audio Component Grounding and Interconnection |
#1218 |
Rtate,
If you unplug the RCA interconnects from the F5, is there still a hum? If not then it is caused by an upstream piece of equipment or cable. Next try, Unplug the other end of the interconnects, CD / preamp / receiver, whatever, leave the interconnects on the F5 side, try them one at at a time, left then right. Sometimes it can be a bad cable. Sometimes the interconnects act as antenna. But you knew that. Try unplugging everything from the power except the F5. Hum still? Is the transformer bolted down tightly? Keep us informed, especially if you DO find the hum source, it will help someone else. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#1219 |
Thanks Guys, I did some investigation when I got home from work and once again Never Assume!!!
Turns out that the F5 IS dead silent. I have a plate amp that is driving the low frequency drivers and that is the source of the hum. So I still have a problem, just not the F5. Now, for some more investigating.... |
#1220 |
Yeah, Congratulations on another silent F5!
Good luck with the "other" amp. Ron
| Page generated in 0.11586 seconds (73.81% PHP - 26.19% MySQL) with 10 queries |
